Question about ASUS M2N-MX Motherboard
Analog output isn't working and shows only high definition audio.
  • 115 Answers
Please download drivers and install from following site
http://www.driverstock.com/ASUS-M2N-MX-driver-download/6-9-10275/index.html
Your problem should be resolve.
Regards
Ashley
Posted on Feb 02, 2010
I need to know what model of a Motorola DVR is compatible with my receiver. What model can connect DIRECTLY from it's audio output to the audio input of my STA-795 Optimus Digital receiver (not through the...
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
Apr 21, 2011 | Optimus STA-795 Receiver
Can you hook the vizio sound bar to an av receiver for use with all devices hooked to the receiver thru HDMI?
Why not ? It doesn't know what the source at the other end of that RCA or digital cable is.
Picking the VSB200 as an example.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Vizio-VSB200-Speakers-manual/id/23494ag923/t/2/
The manual shows connections to just about anything.
Not knowing anything about YOUR receiver, you MIGHT be able to draw digital audio out somewhere. Analog audio would be available at any Tape Output. Your receiver
Mar 23, 2011 | Vizio High Definition Sound Bar
What is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
I do not get sound from my speaker, the control panel shows it to be sending a digital signal. How do I change it to analog so the speakers will work.
Try changing the default sound device from high definition audio output to speakers. You can find it under sound in control panel.
Oct 12, 2010 | Acer Audio Players & Recorders
Can i output component video via the hdmi out on a Yamaha RX-V465?
component video is analog. although it can carry a high definition image, it is not compatible with hdmi.
Dec 26, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
IDT high definition audio codec (code 10)
Try and install the "Modem" first restart and then wait if it ask for a driver in your audio.
Mar 27, 2009 | Dell Computers & Internet
Won't show the picture or sound
Here's one possiblility.
There should be a switch on the x box cable that goes from High definition output to analog.
Try changing the swith setting.
Jan 02, 2009 | Microsoft Xbox 360 Console
ASUS M2N-MX Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
