Question about Sunbeam 2379 Mixer
Motor stopped working
Power light on mixer is yellow instead of green but motor is not working
Mixer stop working powerless
Does it work on liquidy content? If it does the reason for not working could be the mixer too thick for its power and may burn motor.
Nov 07, 2013 | Black & Decker 175 Watts MX150 PowerPro ...
Motor is making noise and grinding sound - only runs at slow speed, Seeing green light inside the motor area
The green light is probably sparks. Does the light eminate from the rear? If so, it sounds like there is an issue with the control plate. Taking the rear off should hopefully help you spot what is wrong with it. I suspect the board has broken or got stuck.
Jan 30, 2010 | KitchenAid 32685 Mixer
Mixer gets hot and smokes when in use.
Smoking and overheating during use does not usually indicate a problem with motor oil. Kitchenaid stand mixers have sufficient oil in them to lubricate the motor for its lifetime.
Smoking and overheating are geneally caused by overuse. Consult your use and care guide or Kitchenaid Customer Service to ensure the mixer is being used properly. Customer Service would also be able to send you a new Use and Care Guide at no charge.
Their toll-free telephone number is 1-800-541-6390.
Apr 26, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Kenwood Chef Restore
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood chef 700w
I think its the control modul that has stoped working ,sadly.
Mar 13, 2008 | Kenwood KM800 Major Classic Stand Mixer
Converrt USA electronic to european electronics
I have the same mixer and I moved from the States to the UK.  I just bought a really good power step-down converter (has to be step-down rather than a standard adapter, and watch the wattage of the adapter).  It worked fine.
Jan 15, 2008 | KitchenAid KSM50PR Professional Series...
Kenwood chef 700w
I hope you didn't buy a new one, ours stopped last week after 25 years. All that was needed were new brushes for the motor. Anyone with a screwdriver could replace them. 4Kenwood had the parts to me in a couple of days.
Jan 07, 2008 | Kenwood KM305 Stand Mixer
Sunbeam 2379 Mixer Logo
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
