Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Ge refrigerator ge profile refrigerator the tempature digital display inside the unit is not working. also once in a while there is a clicking that last a few minutes... The lights in the room also dim when the clicking occurs...
  • 6,784 Answers
HI. This will be the cause of a defective PCB. This circuit board is the main controller of your unit. the clicking is the result of a failed relay assembly. these relays are mounted on the board, itself. The board should be mounted just behind an access panel, on the rear of the unit, slightly above or near the compressor assembly. Kindly have this PCB replaced, asap.
The PCB is , indeed, the culprit in this situation. Once the PCB is exposed, you should visually inspect for brownish discoloring, and relay trauma. Possible power surge may have caused the board to short.
Posted on Feb 01, 2010
The tempature gauge was is too high and the refrigerator is warming up and the freezer is at 26 degrees when it is suppose to be -0.
Your refrigerator is most likely missing defrost because of a defective defrost heater=> WR51X10055 Defrost Heater Look inside the freezer compartment and see if a layer of snow/ice is building on the back freezer wall. If yes unplug and defrost freezer compartment with a hair dryer or by filling a large bucket with hot water and placing inside and closing doors for a while. Be aware that excess water may run out on floor if not mopped up with towels while manually defrosting. You may also remove the rear panel in freezer listed as position 213 in this photo=> PSW26PSSAKSS_Freezer_Component's
and looking at photo you should replace parts 230 and 240. Number 240 is the defrost thermostat=> WR50X10068_Defrost_Thermostat Both of these parts have details of how to test before replacing listed on their links. I always think it is good to replace the defrost thermostat while inside working on the freezer. The thermostat can wear out also causing problems later. I will be here should you have further questions, Thanks, Sea Breeze
GE Artica/Profile=> Service Manual
May 19, 2011 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Profile refrigerator, PSC23SGRCSS not working
I have the same problem with the same model. Did you ever find an answer?
Aug 30, 2009 | GE Refrigerators
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
May 29, 2009 | GE Refrigerators
GE Profile Refrigerator
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
245 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
