Question about Dell Dimension 8200 PC Desktop
My mother has a dell dimension 8200 and it wont turn on. my step-father said he took one of her fans for his computer (they're seperated) but i dont know which one. I want to replace it, but i dont know what fan he took, and she lives in another state, so I cant look at it, would it be the cooling fan? or is there another fan that would keep it from running?
    Scholar:
  • 44 Answers
There are several fans that your step-father could have taken from your pc. They could be the two cooling fans, one at the rear or one at the front of the pc. However, there is one very important fan that could have been removed and that is the fan that sits directly above the processor or cpu, central processing unit. If this has been removed then it's likely that your computer wouldn't boot as the processor needs to be kept cool when operational. You could look inside your pc. Lay it on its side and remove the side panel, if you have screws then these would be located at the rear of the pc. If you do this, make sure everything is disonnected and most importantly, when you have removed the side panel, don't touch anything inside the pc as this can be dangerous to your computer. Just look inside and you should see a raised heatsink, this is a big piece of square metal with fins and the fan sits on top of this. This is the most likely reason if this has been removed why your computer won't start or boot up. Whilst looking inside, try to locate any other fans at the front or rear of the pc. The processor needs to be kept cool at all times. You can purchase individual fans but you would need to purchase one that is compatible with the heatsink you have sitting above the processor. Remember don't physically touch anything inside whilst you are checking out the situation. Your best bet is to check out your step-dad's system and let him show you the fan he removed, you can then order a replacement part online, get the model number from the fan etc. Good luck. Andrew
Posted on Feb 01, 2010
My Dell Dimension 8200 cooling fan started running at high speed constantly yesterday. This pc is 8 years old. Could the mother board be the problem. Any suggestions? I runs well other than the fan.
you a ed to re-grease the cpu.
take off the heat sink thats the big metal lump in the middle of the motherbaord under neath it you will find a it will have like a grey or white paint tye stuff on it chip claen it off with some tissue re-apply new grease from maplins or pc world under thermal heat paste the deerer the the better quality the price is between £5 - £10. then put it back together.
Oct 07, 2010 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 Desktop PC shuts off after it has been on for a long time. It shuts off like power has been removed from the CPU although I have an APC hooked up to it.
Sir you should check the power supply of your system.If its working properly then its because of the heat sink of your motherboard...Try to mother heat sink fans in the pc and your problem is solved......
Aug 02, 2010 | Dell Dimension 8200 PC Desktop
Help - does dell dimension 8200 have ethernet as standard?
As per the Dell Dimension 8200 specification, it does not have an Ethernet port to connect to LAN/Internet on wire.
check this site for more info:
http://support.dell.com/support/edocs/systems/dim8200/specs.htm#1101572
Nov 07, 2009 | Dell Dimension 8200 PC Desktop
Error message Fan Failure press f1
Some of those OEM systems have built in fail safe's like that to try and keep them running longer w/o failing. Just get a hold of Dell and get a replacement fan, they should send instructions on how to put it in yourself! :)
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 Upgrade Heat Sink Problem
you can contact online for techsupport at dell at www.support.dell.com this a live tech support session totally free they have helped me out numerous times keep me posted on how this goes ok best regards mike
Aug 12, 2008 | Dell Dimension 8200 PC Desktop
My demension 8200 wont turn on, no lite no humming Nothing!!!!!!!!!!!
dear skipit91
the solution I posted is the first step we use to follow. By the if you have already cheked the smps of your unit then you should have posted in your follow up.
By the way i dont want to hurt you by any means if any of my words or solution is hurting you then i apologies for that
Jul 24, 2008 | Dell Dimension 8200 PC Desktop
CPU fan died again
what's the output at the mobo connector?
Mar 02, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
