Question about LG GSA 4163B DVD±RW Dual Layer Burner
DVD wont recognise disc
DVD wont recognise disk and cannot open device manager
  • 3 Answers
If your DVD drive don't show up in device manager and if there's no yellow exclamation mark in device manager, try to check IDE or SATA cable connection from your DVD drive to the motherboard. Also check the cable itself (are the wires inside broken?)
Posted on Feb 01, 2010
Dvd writer not recognising any disc.just says insert disc
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 06, 2012 | Computers & Internet
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
My LiteOn iHAP422-98 9 IDE drive will read but not burn CD/RW discs. No problem with DVDs or CD/R. One of two error messages, depending on the CD/RW disc: 1) Doesn't recognise a disk is in the...
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 14, 2011 | Lite On iHAP422 DVD+R Burner
Inserted dvd disc but the computor still asking to insert the disk?
The disk is not being read and so the somputer is not detecting the disc. You willhave to change the whole disc drive to clear this fault as the optical unit alone may not be available. Also you can reinstall the drivers once again to make sure that it is not a sofware issue. Open control panel , then open system manager-device manager and reinstall the DVD-Cd drivers. If this wont solve the issue then you will need to change the unit as a whole. Confirm the cost before you attempt to change or you can alsouse an external one through the USB. Hope you try. good day
Jul 28, 2010 | Televison & Video
HL-DT-ST RW/DVD GCC-4243N wont burn dvds
Try uninstalling the Driver in Device Manager: in XP or earlier: Start/Control Panel/System/Hardware Tab/Device Manager, or in Vista & 7: Start/Control Panel/Device Manager.
Once in Device Manager click on the + sign that is in front of 'DVD/CD ROM drives' to open it up, then right click on the model of the Optical Drive in question.
Click Properties/Driver Tab/Uninstall (Advanced) & this will remove the driver if it is corrupt. Restart your system & the Hardware Manager will recognise the Optical Drive & install the necessary Driver.
If this doesn't solve your dillema then I hope that you have a warranty. Good luck in trying.
Kindest regards,
Ste
Apr 02, 2010 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
Will not detect disc present. I have a Liteon 20x DVD burner. Will not play DVD;s or recognise any inserted disc. When I open it in "My Computer", no disc is visible.
Try opening device manager,and clicking on verything having to do with discs,then narrow it down to what you need.It might work
Feb 12, 2010 | Computers & Internet
Will not recognise dvd audio disc
Check out is your device working properly.
Sep 26, 2009 | LG Computers & Internet
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
My computer doesn`t recognise disk in dvd drive
1. Make sure you use DVD's in good condition.
2. Reinstall the driver..( right click My Computer->properties->Hardware tab -> Device manager-> DVD rom-> right click Uninstall and again install using Dvd rom driver cd)
3. Clean The Drive lens using Dvd lens cleaner disc kit available in maket.
4. Removing DVD rom. opening it up manually and cleaning the lens with cotton( this tedious for novice users.. instead give it to servicing shop)
May 20, 2008 | Toshiba Computers & Internet
Both drives not recognising disks
Have an LG Super Multi DVD Drive, Model:GSA-4120B.
Won't recognize any disk, CD or DVD and won't play any audio video
Device manager says, it's working properly
Dec 28, 2007 | LG (GDR8164B) Internal DVD Drive
LG GSA 4163B DVD±RW Dual Layer Burner Logo
226 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
