Question about Dimplex Heating & Cooling
TO REPLACE BULB IN CHERITON CHT20 FIRE
TO REPLACE BULB IN CHERITON CHT20 ELECTRIC FIRE
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
Does anyone know where I can buy a small black rubber grommet for rotisserie bar on Dimplex Cheriton fire
Yes this is a fairly common rubber grommet usually available at Maplin. They are most used for protecting cables or other things from abrasion from flexing at the entry points into boxes casings or conduits etc.
Search 'pvc grommet' on google
Feb 11, 2014 | Heating & Cooling
Dimplex cheriton fire model CHT20LE wont turn on
Check the fuse isn't blown in the plug. If it is not, then you would unfortunately need to open up the fire and check the internal wiring and connections, check the switches with a multimeter to make sure they are working. There really isn't much inside these units to go wrong! So any fault should be rather easy to find
Aug 02, 2013 | Dimplex Heating & Cooling
No visual fire - did the lightbulb burn out?
Yes - Replace bulb per your owner's manual instructions.
Make sure to use the recommended bulb type & wattage to ensure proper flame effect.
Jan 26, 2013 | Dimplex CS4416 Electric Compact Heater
Changing bulb in dimplex cht20 fire
Yes this is very easy on the cheriton range of fires.... remove the coal, then remove two screws from the front of the coal holder... the whole brass coal holder will pull away from the machine. The bulbs (two of them) are located directly behind this, just behind the rotisserie flame effect. The flame effect can be pulled out of its holder to access the bulbs.
Feb 19, 2012 | Heating & Cooling
Replace bulb in hyundai curved glass fire
Two people required for this
Remove fire from wall
Lay fire on its back
Gently slide glass panel towards top of fire and remove. Store glass safely
At the bottom of the fire there is a lamp cover fixed by 8 Philips head screws.
Remove screws and lift off the lamp cover
Slide the flexible rotisserie to one side ensuring you don't lose the rubber grommet
Remove bulb by pulling it out of the holder (force may be required)
Replace with 40 watt G9 halogen bulb. Take care not to touch the bulb with your bare hands
Push the bulb fully home
Refit the rotisserie making sure the rubber grommet is carefully pushed into the slotted hole in the axial bracket
Refit the lamp cover
Lift the fire back onto the wall and replace glass front by lifting onto the lugs either side of the fire.
Oct 22, 2011 | Hyundai Heating & Cooling
Noisy optiflame motor on dimplex cheriton fire
If you are referring to the motor of the flame effect, these are called synchronous motors (commonly used in microwave turntables. Any syncronous motor should do as a replacement, but check whether you need a 12v model or a 240v model. This information should be found on the label on the back of the old motor.
Nov 30, 2009 | Dryers
Heating & Cooling Logo
160 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
