Question about Mitsubishi SD200 Multimedia Projector
After about two hours the projector shuts off
It may be overheating or on timer mode.
Posted on Feb 01, 2010
3M SCP712 projector shuts down after an hour--can't turn back till it cools
Hello
the problem is with overheating. Look whether the cooling fan doesn't work or air filter is cloggy with dust. OK.
Nov 08, 2011 | 3M SCP712 Projector
HD20 switches on by itself
the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp. Good luck.......
Aug 02, 2010 | Optoma HD20 DLP Projector
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
What would cause a Christie to shut off after 60 secs?
On my Vivid Lite the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp.
Jun 04, 2009 | Christie DS+60 Multimedia Projector
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
My projector keep shutting down
After replace the lamp. Please reset the lamp hours and clean the filter. It should work.
Apr 07, 2008 | Office Equipment & Supplies
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
Mitsubishi SD200 Multimedia Projector Logo
62 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
