Question about Hotpoint Washing Machines
THE FABRIC CONDITIONER COMPARTMENT ON MY BWM129 WASHING MACHINE IS ALWAYS FULL OF WATER CAN YOU TELL ME WHATS WRONG
  • Hotpoint Master
  • 744 Answers
Hotpoint BWM129 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
    Sergeant:
  • 215 Answers
The conditioner works by sythening, to do this water is diverted to the conditioner compartment. Lift this out ond check hole is clear in the little conditioner pot. although this is comman on many machines
Posted on Feb 10, 2010
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
The fabric conditioner drawer is always full of water at the end of the cycle, i have tried cleaning it and running the machine empty but nothing has worked.
fabric conditioner drawer is always full of water This video will show you how to keep your soap draw clear and how to service the parts
Feb 02, 2011 | Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Machine won't draw out fabric conditioner from dispenser
I dont know what model you have but you are correct in your assumption that the conditioner is siphoned out on the last rinse unless it is different for your model.Most machines I am familiar with operate in the first instance.Check that you have good water pressure to all compartments also get a toothbrush and clean the holes above the drawer even a bent piece of wire to unblock the small holes.
Good luck
Apr 12, 2010 | Washing Machines
The conditioner part is always full of water and does not take down any fabric condtioner that is put in. Have cleaned drawer an inside but does not work.
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 18, 2009 | Bosch Washing Machines
Washing machine
Hoover washing machine This video will show you how to keep your soap draw clear and how to service the parts
Feb 19, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Dispenser still full of water and fabric softener
fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Nov 15, 2006 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
268 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
