Question about McCulloch Garden
Not sure if i have kit in wright.I would love to see a diagram. Chain saw will only start with a little starting fluid in the cylinder.
    President:
  • 2,220 Answers
Did you change all the fuel lines? Did you install a carburetor kit? Please clarify your question. Thanks
Lou
Posted on Feb 01, 2010
Husqvarna 137 chain saw - put a new plug in and won't start run if you put a small amount of gas in plugfor just a second or so made sure gas line is not stopped up from tank to carb. less than 2 yrs...
Sounds like the diaphragms in the carburetor have gotten dry and won't flex anymore. Install a new kit in the carb and recalibrate the screws. You should be good to go.
Nov 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My poulan saw keeps stalling and has no power
Check the fuel filter, air filter, and muffler for clogging. Check the fuel lines for condition. The carburetor may need cleaning and re-kit. Make sure the chain is being properly oiled and sharpened. Good luck!
Jun 10, 2010 | Poulan PP4218AV 18" Chain Saw
My husqvarna 61 starts fine and runs great for about 15 seconds and the it flat out stalls. Over and over this happens. what can i do?
Make sure the chain can be turned by hand and is well oiled. Check the muffler, fuel filter, and air cleaner for plugging. Check the condition of the fuel lines and primer button--does the primer pull fresh fuel into it when pumped? Check the carburetor fasteners for tightness including the mounting to the cylinder. If there is a rubber isolator between the carburetor and cylinder, check it for cracking or any holes. Make sure you are using modern synthetic saw oil in the fuel, not boat motor petroleum based oil. If still acting up, clean and re-kit the carburetor. Hope this helps!
Jun 09, 2010 | Husqvarna Chainsaw Piston Kit for 61...
I need a drawing of a carburettor on a 61 Huaqarrna chain saw\r\nwhere do I get it? It is a husqvarna Chain saw
You didn't specify of its a 61 or a 61 Rancher. Here's the info you need to take to your Husky dealer. The diagram will be with the major repair kit.
Model 61, then the 61 Rancher:
CARBURETOR Model 61: ecblank.gif Tillotson HS-163A, B , HS-254A series or
Walbro WS series
MAJOR REPAIR KIT: ecblank.gif RK-23HS for HS-163A MINOR REPAIR KIT: ecblank.gif DG-5HS/T for HS-163A
CARBURETOR Model 61 Rancher: ecblank.gif Tillotson HS-163A series or
Walbro WS-17A, B series
K10-WS
D10-WS
May 18, 2010 | Husqvarna Garden
I think I am missing a part for my Remington lnt-2 12" chainsaw
You do not give us a model number to verify this will work on your saw.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the "YourModelNumber" - Remington Electric Chain Saw "View Model" link.
  • Click "View Owners Manual" or "View Illustrated Parts Diagram" link.
    • Type "YourPartNumber" into the "Search for your parts by Part #:" window, then click search.
A tension repair kit is available here:
MasterParts.com
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=108640-MD
Part number 108640-MD; DESA SPECIALTY PARTS: KIT, ADJUSTMENT SCREW FOR SPROCKET COVER (REM-18); $5.95.
Kit fits the following covers: 108640-01, 116675-01 and 108641-02 (note: for the 108641-02 the screw will adjust from the front with a screw driver, not with a thumb screw at the back) KIT INCLUDES: screw, clip & adjustment block.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 21, 2010 | Remington Electric Chain Saw
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need diagram of husqvarna 141
Not sure why you would need these! This is a really simple process. Remove bar and chain brake cover. Disconnect choke and throttle lever, muffler, and 4 screws with your allen wrench, i've never even attempted it before and just took my about an hour to complete the entire process. Just make sure to note how carb goes together, you can mix a few parts up if your not careful.
You can find aftermarket kits to with cylinder, pistion, rings and all for around $60-100.
Apr 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My chain saw starts but won't move the chain, and shuts off when
Make sure the chain brake is not engaged.Pull it toward the handle until it latches.Also check for sawdust under the chain sprocket cover.Adjust the chain to remove slack but make sure you can still move it by hand.
Apr 07, 2009 | Poulan PP4218AV 18" Chain Saw
Chain saw.need rebuild kit for model 500vl carborator kit
what does a chainsaw have to do with a linksys router? but anyway try looking it up on google
Mar 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
What is the size & pitch of the Wild Thing?
Moto tool makes a set of grinding stone wheels with the 3 common sizes, it is the best set up around and cheap to buy.
Nov 29, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
44 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
