Question about Kettler Coach LS Programmable Rower
How do I clear the odometer....the manual does not specify...
I have the Coach LS Rower (not programmabe). I removed the battery and this reset the odometer to 0. Hope this helps. Not sure if the programmable model is the same or not.
Posted on Feb 21, 2010
What fuse is for odometer lights
didnt specify vehicle --generic answer--if you have your owners manual or look in the fuse panel [s] for dash fuse if fuse good than may have to replace bulb/led which would entail removing dash cluster
Aug 20, 2016 | Cars & Trucks
Harley trouble shooting
First, check for any error codes:
The speedometer is capable of displaying & clearing speedometer , tachometer TSM/TSSM , HFSM , ECM , ABS Diagnostic Trouble Codes also known as DTC's.
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
If you DO get any error codes, repost them for diagnosis.
Aug 05, 2014 | 2006 Harley Davidson FLHR Road king
What can i check?
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
Jul 30, 2014 | 2005 Harley Davidson FXSTS - FXSTSI...
2006 road glide stalls
First off, did you pull any error codes?
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
Jul 21, 2014 | Harley Davidson FLTR-FLTRI Road Glide...
How to get fault coedes of a harley 2013 sportster custom
To enter diagnostic mode press and hold the trip odometer
reset switch while turning the IGN ON.
2. Release the trip odometer reset switch. "diag" will appear
on the odometer display.
3. Press and release the trip odometer reset switch. "PSSPtb"
will appear on the odometer display.
4. PSSPtb indicates the different modules that could display
codes if equipped.
Table 2-1. Modules That Set DTCs
DESIGNATOR MODULE
P ECM codes
S TSM, TSSM or HFSM codes
SP Speedometer codes
t Tachometer codes
b ABS codes
5. Quickly press and release the trip odometer reset switch
to cycle through the letters. The letters will flash as they
are selected.
6. Once the corresponding letter is flashing to the desired
module press and hold the trip odometer reset switch.
7. If no DTCs are present, "none" will appear on display.
8. If any DTCs are stored in the module, either current or
historic, they will appear on the odometer. Quickly pressing
and releasing the trip odometer reset switch will cycle
through the stored DTCs.
NOTE
The ECM will show "no rsp" if the engine stop switch is not in
the RUN position. Verify the engine stop switch is in the RUN
position.
9. If odometer displays "no rsp" then the motorcycle may not
be equipped with the module. If the motorcycle is equipped
with the selected module then go to other modules and
look for applicable communication codes.
10. When all the DTCs have been cycled the odometer will
display "end".
11. To clear all the DTCs in that module press and hold the
trip odometer reset switch. If DTCs are not to be cleared
quickly press and release the trip odometer reset switch.
The part number of the module will be displayed.
12. Press and release the trip odometer reset switch again to
continue to the next module.
13. Turn the IGN OFF to exit diagnostic mode.
Jun 24, 2014 | 2003 Harley Davidson FXSTD Softail Deuce
Clear engine codes
In the diagnostic mode, when you're in the diagnostic module with the error code(s), clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button.
Apr 26, 2014 | Harley Davidson FLHRC Road King Classic...
Odometer flashing
You need to specify which light is flashing. I'm assuming it's the engine light. It could be a range of things. You need to hook up an OBD II to your vehicle and check the fault code. An auto electrician can do this or you could buy an OBD II for around $200.
Mar 25, 2014 | 2005 Mazda 2 1.25
2005 Harley Davidson road glide When I throttle up the check engine light comes on When I hold a steady throttle the check engine light goes off I have replaced the fuel filter fuel hoses with factory...
Pull any error codes.
How?
3 - Turn the ignition switch on and then release odometer reset button. The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
5 - Each letter represents a area of the diagnostics module. The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
11 - Turn the ignition switch off to exit the diagnostic mode.
Once you have any codes, look them up, or post here (I have a manual that translates the codes), to find out what they mean.
Jan 01, 2014 | Motorcycles
Hi, how do i put off ''maintenance required'' sign on my toyota camry 2007 car dashboard?Just did the servicing, the sign is still there?
with the key in the off position press and hold the odometer trip reset button on the dash. Turn the key to the run position while continueing to hold the reset button, do not start the car. The odemeter display should change to all dashes and then the dashes will start to go off one at a time. Once they are all out the odometer will display all zeros and then return to its normal display. Sometimes the trip A odometer needs to be displayed before starting and sometimes the trip B.
Your owners manual will give you some more insight if needed.
Sep 29, 2010 | 2007 Toyota Camry
Kettler Coach LS Programmable Rower Logo
358 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
