Need to remove the "top cover" of my Compaq Presario 12XL400 (actually a 12XL426)to get to the power on micro switch. I can remove the palmrest, keyboard, heat sink, cd-rom, 2 hinge covers - but I can't get the U shaped top cover to come free. Any ideas??? - would love a link to a "service manual" Thank You, Doug
  • 2 more comments
  • SLODoug Feb 19, 2008
    Thanks. There are a lot of tabs - but sequencing isn't the only issue.
    Is it necessary to remove the LCD before I can remove the top cover?
    Thanks
    Doug
    This is a laptop - Compaq Presario 12XL400 (actually a 12XL426) from about 2001.
    This unit has a hinge cover on the left and right hinge - and a center cover that may conceal a center hinge.
    It is the center cover that seems to be concealing screws that would release the top cover - and I cannot even tell if the center cover is part of the top cover or is removeable.
    Thanks Again,
    Doug
    Hmmm...I'm still unclear. I don't want or need to disassemble the LCD. I may want to remove it - so I can get the top cover of the laptop off. The top cover I am referring to is a large plastic thin U shaped molded piece (about 13 inches across the U with two 6 inch legs of thin molded plastic making up the legs of the U.
    I need to remove the laptop top cover so that I can replace/repair the power-on microswitch.
    Thanks for giving this you good thinking.
    Doug
  • deano53 Mar 04, 2008
    I would like to remove the cover to change to an ethernet adapter to connect to the internet
    Genius:
  • 3,587 Answers
That has a load of screws or tabs alongside the chassis, that you need to press(tabs) in sequence. be gentle, as those can snap off mighty easily.
Posted on Feb 19, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Feb 19, 2008
    is this a desktop or a laptop?
  • Patrick Michaels
    actually..now that I'm clear on this..it's not that hard..there is a little panel above the keyboard that comes out, and reveals the screws holding the lcd in place. keyboard MUST come out first though, to release the connector for lcd.
    then, there will be 2 or 4 screws in back or bottom of laptop, holding lcd to main part. remove those, set them aside safe.
    then, with a very gentle touch, and a super thin blade, starting at the place at the bottom(closest to you on the lcd) start the process of easing the bezel from the lcd. you may need to remove some bumpers from the front of the lcd, and remove some screws under them.
    then, there are a series of screws along the sides of the lcd..take them out..
    and then you are there.
    hope this is enough to close this account
  • Patrick Michaels
    got it..those screws are under the unit, and need to be removed from the bottom. some of them may be an odd size, so keep them separate, ok?
I forgot my bios password compaq presario 900 password bios cen you help my
Before removing the RTC battery, follow these steps:1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn thecomputer on, and then shut it down through the operating system.2. Disconnect all external devices connected to the computer.3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet andthen unplugging the AC adapter from the computer.4. Remove the battery (see Battery on page 34).5. Remove the following components:a. Hard drive (see Hard drive on page 37)b. Optical drive (see Optical drive on page 44)c. Switch cover and keyboard (see Switch cover and keyboard on page 46)d. Display assembly (see Display assembly on page 50)e. Top cover (see Top cover on page 55)f. Fan (see Fan on page 58)g. System board (see System board on page 60)Remove the RTC battery:1. Turn the system board upside down, with the audio connectors toward you.
found here: http://h10032.www1.hp.com/ctg/Manual/c01295803.pdf page 65. you'll have to pull the battery for 5 minutes and then reinstall and all cmos passwords should be cleared! good luck
Jan 27, 2012 | Compaq Presario Notebook
Compaq Presario s3310cl starts when hooking in power plug and will not shutoff using power button. Just started doing this today. Someone said to unhook everything and hold power button in for 20 seconds...
The On/Off switch is mounted inside of the Case Front Bezel. It is
very unlikely that it is broken. The problem is the front bezel
plastic switch (which is not really the switch) is more like a cap or a
knob that comes in contact with the actual switch is somehow broken.
You can remove the front bezel to see I am talking about.
Manually push On/push Off on the actual switch and your system will turn
On and Off like it should.
Jul 17, 2011 | Compaq Presario S3310CL (DF246AR#ABA) PC...
I have a hp-compaq presario c300 and i forgot my power- on password. i need help! or need backdoor password in order to fix. please!
NEVER install a power on password without making a note somewhere as to that password is - there is no fix appart from replace the m/board as the POPW is within the cmos chipset - there is a rest button on the m/board but I do not think it will clear this problem. It is located under the top cover just below the mouse input port - requires removing the top cover - screen keyboard ect.
Jun 16, 2010 | Compaq Presario Notebook
How do you remove the actuall keyboard on a compaq presario 1200 notebook computer, i have removed all screws and access doors on bottom end, along with the memory etc.
First remove the top plastic strip piece (where the power button is located) and then use a phillips screwdriver and unscrew the screws holding the keyboard in place. Gently pry it out and then remove the ribbon cable that connects the keyboard to the mainboard
http://www.refurbished-laptop-guide.com/how-to-replace-laptop-keyboard.html
Nov 04, 2009 | Compaq Presario 1200 Notebook
Power switch will not power comnputer - does anyone know exactly what I need to fix this problem and where to order.
Presario power switch assemblies are only made for and sold by HP. If the manufacturer will sell you one (which I doubt) you will need to contact them at HP.com.
There is nothing unique about a power switch, any momentary on contact will work. Have you tried shorting the two pins to see if it is actually a switch problem?
May 17, 2009 | Compaq Presario 6350US (808736414036) PC...
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
I can't remove cover to Compaq Presario to add memory.
Turn the computer around so you are looking at the back. There is a white plastic latch on the right side near the top. Press the latch down and slide the right side (actually the machine's left, but you're looking at it from behind, remember?) panel back toward you. Then you can lift it off the machine. There may be a screw in the top of the panel above the latch, so check for that if the panel won't slide. Compaq doesn't put that screw in at the factory, but someone else may have. Once the side cover is off you will have clear access to the system board.
Jan 18, 2009 | Compaq Presario 5BW284 (202493-003) PC...
Compaq Presario 1000
I have a Presario X1050, not sure if they are similar. Remove the screws from the bottom, carefully remove the keyboard with a small flat head screwdriver. You'll find many screws hidden by small plastic covers and rubber feet that will all need to be removed with the screwdriver. You may have to remove the display to get inside the laptop. Ultimately though, the power supply is actually external included on the power cable.
Jul 01, 2008 | Compaq Presario Notebook
Replace CD-Rom Drive
solution: open front blue magnetic case door, look on either side of the power button, there are finger holes in the other blue cover.
lift out from bottom to top. this cover comes off, not the whole
case. inside find tabs next to cd drive, squeeze and pull out. note: the side sliders were they come out, they will come off the
cd drive when removed. it is easier to replace the top drive by removing the bottom drive, put in the top half way, then put bottom back in half way and slide them in together.
voice of experience. hope this helps
Jan 12, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 700 PC Notebook keyboard locking out
Check that your notebook power settings are correct, it may be that when you press off or shutdown it's actually going into hibernation or standby, this is only correct when you close the lid without shutting down through Windows. As for Windows Media Player, you cannot remove it as it's a Windows component, you can only dissable it through Add/Remove programmes>Add/Remove Windows Components.
Dec 17, 2006 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
202 people viewed this question
Alun Cox
David Payne
David Payne
