Question about Radio Shack 3808 Digital Answering Machine
Error message I cannot find what "A2" means. It alternately blinks with 00 in the display window.
A2 is announcement only, no recorded message possible.
Posted on Feb 22, 2008
Pro-Plus error Panel 03
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
to external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
Remember PCA, mean Printed circuit assembly with the componentsattached.
God bless you
Jan 14, 2013 | Exercise & Fitness
E:61:00 on display window
Hi there:
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
• Turn the camera off
• Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
• Turn the camera on
• Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
• Lift the camera away from the hard surface and notice that the error message is gone.
• Take pictures of your favorite things.
Here is the first alternate method (AVI format)
Here is the second alternate method (AVI format)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 20, 2012 | Cameras
Hi there:
Nov 20, 2012 | Sony Cyber-shot DSC-W110 Digital Camera
My v fit treadmill is not working. It is displaying E1. Is this a trouble shooting code?
Dear Sir:
Hello, I am glad that you contact us.
I will give some Tips:
1) Your Error C is for Troubleshooting, only that message, is must be special some times.
2) Your Error C, has some interpretation depend of the factory.
3) Example: E 01: Mean Replace VSD( Variable Speed Drive) to due some Microprocessor Chip Failure: The Option will be replace Board VSD, but you must contact to the Company for to Fix the Board.
4) The another Alternative: If your equipment has Servo Motor:the enconder is Malfunction: You must Re-Start Machine, and follow again. If the problem persist, You must exchange: a) Servo Motor b) or The Drive Board.or Both.
5) The following alternative is:
Description
Possible Causes
Possible Remedies
I hope that you can resolve this, and take your final step.
Thank you in advance, sincerely. God bless you.
I you Need additional help, you can reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Exercise & Fitness
E:61:00 error
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
· Turn the camera on
· Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
Good luck.
May 03, 2011 | Cameras
E:61:00 on the display
E:61:00 means "Difficult to adjust focus Inspect the lens block focus reset sensor"
goodluck
and do rate the solution if helped
Dec 06, 2010 | Sony Cyber-Shot DSC-P71 Digital Camera
Error message HO2 shows on vhs display
the player begins to read dvd. display will read 00---READ and it repeats this process a few times and the error then is displayed next.
Jul 10, 2008 | Panasonic Televison & Video
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
Radio Shack 3808 Digital Answering Machine Logo
178 people viewed this question
Top Radio Shack Lands Phones Experts
ismael castillo
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
