Question about Canon Office Equipment & Supplies
The main tel line goes into 2way splitter one for high speed internet, the 2nd goes to mx 310 canon all in one , can send fax but i cant receive any , i tried my level best with out >>>>>>
  • 3 Answers
Do you have a filter on the line? usually, you need a filter to keep the phone and data sides separate. Fax machines are generally treated as phone devices. If you are in the US, ask around, chances are somebody has a filter you can use, I know I've probably got half a dozen in a box somewhere from every time I've had dsl set up.
Posted on Feb 01, 2010
I have a canon IR 1025IF that will not receive faxes but will send faxes
You should check your telephone and fax set up. Also check the settings on the machine to see if it is set for Manual receive or Fax/Tel, and the number or rings before pick up. If you are on an ADSL internet connection, you should fit or check that the line filter is working. The Fax line should be connected through the filter
Oct 31, 2017 | Canon Office Equipment & Supplies
Can not receive or send fax. There is the phone tone on the BT line.
When we are speaking about faxes you have to try at least a few numbers, because there is sometimes a temporary problems with tel line speed. To send or receive the fax the tel line should be stable. Fax machine try to connect to highest speed (33,6 by default) and if the line is not stable you will receive connection error.
Try again but tomorrow or ask yout telephone company if there is a problem with line
pifonski
Feb 20, 2011 | Samsung SF-5100 Plain Paper Laser Fax
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
I bought a Canon product : PIXMA MX 310 on the 27 th october 2008. DMO - ISRAEL sold me the unit. I can't use the FAX - the recieving system doesn't work. I have an answering machine on the tel....
your answering machine is probably picking up the calls before the fax try to use a separate number for the fax or just disconnect the answering machine and get someone to send a test fax to see if it works
Nov 16, 2008 | Canon Office Equipment & Supplies
Fax machine cannot sed or receive faxes
tell me the model of your Fax Machine
Nov 11, 2008 | Office Equipment & Supplies
Canon MX 300
I cant send Fax. I also receive a message ''waiting for report''and"memory receive mode". Please Help
Sep 17, 2008 | Canon MX300 Office All-In-One Printer
old marine
old marine
