Question about Samsung SyncMaster 213 T 21.3" LCD Monitor
Monitor does not come on
I get alternating "analog", "digital" and "check signal cable" messages flashing on the screen. Have replaced the signal; cable to no avail.
    Champion:
  • 220 Answers
Problem related to interface board.
Posted on Feb 19, 2008
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
Monitor stopped working - says No signal
Hi Paul,
This problem is often the result of a loose video cable connection on the computer or an incorrect video signal selection. Most monitors use a cable with "VGA" connector on the end that mates to the computer video port. Other modern computers make use of an HDMI (like the ones used to connect a TV to a BluRay Disk player) or DVI connector instead - either way if it is loose you will get the same "No Signal" message on screen. Make sure these connectors are making good contact with the port on the computer by seating them fully (or better yet - remove and reinsert). In the case of the VGA connector, most have two screws to hold them in the port - you should make sure both are threaded all the way in. You do not need to crank them down, finger-tight is more than enough.
Many newer - flat screen types in particular - do not have the video cable permanently attached. Instead, they use the same cord and connector arrangement found on the computer. It is possible that the connector has become loosened on the monitor end - especially if the monitor is moved / adjusted frequently. You should check the connections at the rear of the monitor just as you checked at the computer, too.
When satisfied that the connections at the computer and monitor are good, check the monitor again. If the message is still present, the monitor may be able to select between an analog input and a digital input via a menu item accessible from the monitor. Check your monitor manual for instructions to change inputs if unsure. If you are using the "standard VGA cable" (the one with the two screws) you should select the analog input. If you're using an HDMI cable, you should select the digital input. If you're using an DVI connector the input may be either analog or digital. When making a change, wait 5 to 10 seconds between toggling between the analog / digital selections to allow the monitor to sync the signal for proper display.
If you're still unable to display the desktop, it is possible that that someone has changed the BIOS options to select a different video card (if more than one is installed) or that the cable is defective.
I hope this helps and good luck!
Dec 17, 2012 | Computers & Internet
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Screen flashing, message NO SIGNAL
This means it is not getting any signal from you computer. Check all connection on both the monitor and the computer to insure they are tight. Some monitors have both a analog and digital input, if this is the case on your monitor there is usually a button on the monitor that will allow you to switch between the two, usually has an arrow pointing to a box.
Jan 22, 2010 | Computers & Internet
I have s samsung monitor T220 and will not come to show that my computer is connected, I have a message on the screen that says check signal cable with the word digital at the bottom of the message box....
oh i had the same issue with T220, remove all ur memories , disconnect the monitor , remove the graphic card, clean it and instert it back , insert the memories and then connect the monitor to analog cabl;e first,,, put it on and then shut it down and then move back to digital sorce with the cable changed
Jan 11, 2010 | Computers & Internet
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Samsung SyncMaster 213 T 21.3" LCD Monitor Logo
215 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
