Question about HP Mini 1000 Netbook
My HP mini netbook won't reboot.
I was turning off my netbook, but as it was shutting down, it started to install updates (which was what it usually did). Now, I know that you weren't supposed to shut the comp. off or unplug it while it was installing. However, I accidentally stepped on the laptop's cord, thus, unplugged it. Now, whenever I turn my laptop on, it's said, "BOOT MNG is compressed. Press Alt+control+del to restart." That's exactly what I did and it always showed the HP sign with "F9 to change BIOS...", "F10 to..."  I pressed F10 and ran a diagnostic, nothing seemed to be diagnosed as defected. But then my laptop won't start up either. It will either stay as "BOOT MNG is compressed..." or "Press F10..." or "Press F9" What shall I do now? Thank you.
  • HP Master
  • 2,517 Answers
Press power botton then F8. few option there. select " last known good configuration ...." select & press enter & again enter. Systen start run again. If you found the same error then i suggest formate your OS and reinstalled it.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Posted on Feb 01, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Connect an external USB CD/DVD drive.
Put in a Windows operating system CD or DVD. I'm not sure it matters which one in this case.
Boot up the computer using the CD.
When the first set of choices come up, type in "R" to get the Recovery Console.
When the Recovery console comes up, type:
fixboot
Then remove the CD and reboot.
Posted on Dec 12, 2010
HP netbook won't turn on
Remove main battery and try again, if no! have the power adapter checked for correct voltage, if okay! the DC jack in the laptop is a common source of trouble, at this point it must be dismantled down to the mother board level and checked, I recommend a pro to address the situation.
Apr 13, 2012 | HP Mini 1000 Netbook
My hp mini won't shut down or show the task manager
You will have to figure out what the lockup is as well. That could be a program or windows or even a overheating issue as the cause. Or it can be one of those things that it just does to irritate the heck out of you and you never can figure it out ;-]
The first step is you need to shut it down. You can push and hold the power button down. If it is just a software thing this usually is enough to shut it down. The next thing to do is to take out the battery. The battery will cause windows to complain a little that it wasn't shut down properly and will want to check things on reboot. Let it do that. Once you can shut it down then you can start trying to watch for symptoms when you reboot. You can check for warm spots on the chassis or maybe a program you were running or started or in quite a few cases nothing at all.
Sep 13, 2011 | HP Mini 1000 Netbook
My hp mini netbook wont turn off
It is PROBABLY downloading one of those infernal updates that seeem to happen twice a week...
If you need to force any PC down, hold the power button activated for over 6 seconds to force power off.
May 08, 2011 | HP Mini 1000 Netbook
What are the key button on my hp netbook to reboot it factory settings plz
if the netbook is setup like the normal notebook, usually the F10 key starts the recovery process.
Apr 14, 2011 | HP Mini 1000 Netbook
My HP mini 110 have a bios password how i reset it?
you have a tutorial here...i hope it will help you
http://www.governmentsecurity.org/forum/index.php?showtopic=2411
Feb 12, 2011 | HP Mini 1000 Netbook
When I try to turn my netbook on, it freezes at the first screen where it has the HP logo in the center. And it says "F9 change reboot order. Or F10. Something else. I don't remember the F10 part....
You are trying to boot from a non bootable device. Start up your netbook and change the boot order to Hard Drive or Drice C, then re boot. F10 will store the settings.
Hope that helps
Dec 13, 2010 | HP Mini 1000 Netbook
Need for speed 3 hot pursuit is a low graphic game but it is not working properly on my hp mini 210-1085Tu netbook.......plz suggest some solution for my problem.
Sorry to hear that. Unfortunately, Netbooks computers are not made for games. You are lucky if you are able to make it work.
The only solution you may have, is to check for driver updates at the HP website and update the VIDEO driver.
The HP Mini 1000 Netbook usually do have an Intel graphics chip, check the game specifications is it works with Intel Chips.
Good luck.
Nov 23, 2010 | HP Mini 1000 Netbook
Netbook has been installing update 17 of 30 for 16 hours. States: do not power off or unplug your machine. Please advise.
The registry has a glitch in it. Turn off and reboot and start over with the down loads
It is the only way
Aug 01, 2010 | HP Mini 1000 Netbook
New HP Mini w/ Windows XP ''Remote Procedure Call'' Shuts down
Hello.
This may not be the answer you are looking for, but in my opinion, if you are experiencing system problems after a couple of days, I'd advise you to return the mini for a new one. If the supplier doesn't have a 30-day return policy, then contact HP.
Hope this helps.
Dec 17, 2009 | HP Mini 1000 Netbook
Hp mini wont start
i had a similar problem. this made my netbook start again. turn off your netbook and then remove the battery. then (with the battery still out) slide the power switch into the on-position and hold it there for a minute. then reinsert the battery and turn on your netbook. as soon as it turns on, keep repeatedly pressing the F10 key till you see your screen light up. then login normally and go to the hp site and download the driver for your netbook. i think its under BIOS? hope this helped. sorry if it didnt...
Apr 08, 2009 | HP Mini 1000 Netbook
HP Mini 1000  Netbook Logo
820 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
