Question about Epson TM-U220 Matrix Printer
On an Epson model TM-U200B I use the following print command to line feed after the print job and to do a partial cut: <0A><1D><56><42><10> My problem is that when I change the number of copies from 1 to 2 I cannot get the printer to do a cut between copies. Ia this something you can help me with?
  • 3,741 Answers
Cutting the Paper The following procedure will cause the printer to print the entered text and then cut the paper. ----- 1. Select any font other than "control" from the font list. 2. Set the font size as desired. 3. Type in the text you wish to print. 4. Hit the Enter key. 5. Select the "control" font from the font list. 6. Set the font size to 10. 7. Type in an "F". 8. Open the File menu, and click on Print . When you click on Print, the printer prints the text you entered at Step 3 and then executes a full cut. If you wish to execute a partial cut instead, enter a "P" rather than an "F" at Step 7. (But note that some printers cannot execute a full cut.)-------
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 01, 2010
Paper not feeding
Hi
Open it up and check the installation of the labels.Make sure the roll is correctly fitted.
Turn it off and on.Solved?
Turn the printer off .
Press and hold the power button and then turn printer on.
Release the button.
The printer will print a test page.
Try feeding now.
Mar 01, 2012 | Epson TM U200B Matrix Label Printer
Download driver m119b
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Jan 14, 2012 | Epson TM U200B Matrix Label Printer
To install Epson printer TM-U220PD Model M188D
What is the baud rate of the EPSON TM-U220D MODEL M188D?
Feb 14, 2010 | Epson TM U220D Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
371 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
