Question about Sony KV-20S20 20" TV
Sony KV-20S40 stuck on channel fix
Just given a Sony KV-20S40. It is stuck on "channel-fix" and without the manual, I am having trouble turning this off! It is not hooked up to anything but the cable, so I want to change channels directly. The display screen tells me "channel fix off" but clearly it is not???
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Posted on Apr 21, 2010
Switiching of channels lock or what? from remote
http://static.fixya.com/Manuals/S/Sony/KV_32FS10_32_F1C26384514711D8952CC18F39A1BA48.pdf
read manual (pages 27 and 28)
Nov 28, 2013 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony KV-32FS120 32" TV Will not stay on a TV channel
It sounds that the main system memory IC of your set has either damaged or confused. Just make a factory reset. If this do not help you, replace the memory IC
Apr 30, 2012 | Sony Televison & Video
Sony Trinitiron 27 inch. It's stuck on channel 27
go to menu then channel turn off channel fix that might help ya
May 24, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv is stuck on channel 25
30 YR SERVICE TECH
THER ARE NUMEROUS THINGS THAT MAY HAVE CAUSED YOUR PROBLEM. TAKE IT IN TO A SONY AUTHORIZED SERVICER
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv-x2982u - how do I tune a channel in?
I have KV-X2982U, With the television on 4, Grip the top side of remote control RM-833 and reverse it, putting it back in the holder. Press Menu on the remote. Several options appear. Press the white button "Preset". You can then manually tune in the setting to channel 4 by pressing the green button, or alternatively you could tune in all channels automatically by pressing red. You may get a better signal on the other channels this way. Good Luck.
Jan 16, 2008 | Televison & Video
Sony KV 20S40 20" tv flutters, reduces in size and then shuts off
The set most probably has cracked solder joints in one of the deflection circuits, which is pretty common. The picture tube and major components are fine. A good tech can quickly resolder the main board and that should not cost too much. If your set came into my shop I would charge about $50 but ask around, the shops in your area will vary.
Jul 31, 2007 | Sony KV-20S40 20" TV
Televison & Video Logo
525 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
