Question about Acer DX900 Smartphone
My acer dx 900 pda wifi indicator does not shut off, and as a result i think thats one of the reason the battery dies so fast. when the wifi button is selected in comm mngt it does not respond, so in a nut shell no wifi, battery dies fast, phone reset all data settings if it shuts off or restart. what can be done do i need a upgrade to wm 6.5, if so how is it done step by step
  • express72 Feb 01, 2010
    i cant seem to get these patches open i am using a mac, or do i have to download the patch on a pc?
    i cant get the patch download
  • 2,069 Answers
Wouldn't want to think that its purelly the indicator that is causing battry to die fast.
Get a patch from here for your set. also check here for more instructions.
Regards
Posted on Feb 01, 2010
  • Muzahura Frank Feb 01, 2010
    Download patch to your pc, unzip using winzip or winrar, send the unzipped fplder to your dx900. your handset( smartphone) will identify it once you try to open it and install the patch.
    Regards
    Did you navigate to where there are 3 patches? I would recomend you only download and install the one for battery life only if your phone otherwise works well.
    I am otherwise moving out of office. its now 6:00pm here. so untill tomorow 8:am
    good luck.
Where do I find the MAC address so I can have it recored with the company so I can use their WIFI
Posted on Jul 10, 2010
2015 Polaris 900 won't start. Was starting with fast idle, rough running with backfires, now won't start at all. Was running perfect.
fast idle start usually indicates an air leak somewhere.check carburettor bolts are tight and engine head bolts are tight.try that first
Feb 19, 2015 | Polaris 2015 Ranger XP 900
My Jandy PDA has stopped working. It started to
need new PDA hand held make sure to replace with same model old ones 800 MHz new ones 900 MHz means change antenna also
Apr 05, 2010 | Jandy AQUALINK RS TELELINK KIT
I have an acer aspire 5315. Don't think I've wifi.
if you're using your pc as a gateway to connect to the internet you need to make sure the pc is turned on and connected before you connect wirelessly from your laptop. alternatively you can connect directly to your wireless router from your laptop, eliminating the need to use your pc to connect
Mar 01, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 5520 would not proceed to boot up
Tried replacing the memory. It worked for me. I tried removing battery, harddrive etc. Same thing: briefly power light on and fan on and then both off.
Jun 04, 2009 | Acer Aspire 5520-5908 Notebook
Acer Travelmate 4670 Power Button LED
Check your power settings:
Start
Control Panel
Performace Information and Tools
Adjust power settings (in left hand collumn)
Whatever is indicated with a bullet in front of it - click "Change plan settings"
Then choose "Change advanced power settings"
Make sure your Power Button is not set to hibernate instead of shut down.
Good Luck.
Apr 06, 2008 | Computers & Internet
My laptop won't connect to wireless internet unless it is running off its battery. As soon as I plug the laptop into a power source, it automatically disconnects from the internet and I cannot get it to...
It seems the two oval lights on the front of the Acer TravelMate 3003LCi are not only lights to indicate WiFi traffic, but also buttons to turn the WiFi radio on and off for security reasons. If you press and hold the left side button for 3-5 seconds it should turn back on the WiFi radio. Windows XP (and maybe other OS’s) have a power saving function that turns the radio off when not in use to save the battery, so you have to use the buttons to turn the radio back on. Seems like a pain in the @$$ to me, but it’s a clients laptop not mine so he will have to live with that.
I hope this helps someone so they do not have to go through the frustration of trying to figure out why the radio has been turned off.
Nov 04, 2007 | Acer Aspire 5050-3242 Notebook
Acer 3003LCi - Wireless Connection
Oct 19, 2007 | Acer Aspire 3003LCi Notebook
Acer N50 sometimes it doesnot turn on
Hey, I had a similiar problem with my pda few years ago. It didnt turn on, or then the startup info screen came up and the pda just froze or shutdown. I had to hardreset also to get it runing. After a few weeks of this the pda died. It's possible that your pda is about to reach its end. There could be other problems. One thing you could try to do is reinstalling the operateing system if you have such. You can also buy newer operating system upgrades but might not be available for your product and it might not fix the problem if it is a hardware issue. Good luck.
Oct 15, 2007 | Acer n50 Pocket PC
Wi-fi PDA connectivity problem
First, restart your pda by using your stylus and pressing the pin-hole sized button on the back of the PDA. There are sometimes a couple of different reasons why the pda wont recognize the network. Main Reason: Make sure you are at the home screen... Tap the wifi icon on the lower right corner of the pda. T hen make sure that the WLAN power is turned ON. Press the setting button. If you see your network in the list, tap on it. It should bring up a network configuration window. Make sure it says it connect to "The Internet". Then tap on the "Network Key" tab at the bottom of window. If you have no security settings on your belkin router, make sure Authentication is set to Open and Data Encryption is set to "Disabled". Then press "OK". That should Be it!!!! Let me know if this way doesnt work, or if something doesnt make sence!
Sep 15, 2005 | Dell Axim X50v Pocket PC
Acer DX900 Smartphone Logo
290 people viewed this question
Top Acer Cell Phones Experts
Computer Repairing
Computer Repairing
Thomas Perkins
Thomas Perkins
richie46
Are you an Acer Cell Phone Expert? Answer questions, earn points and help others
