Question about Bunn GR10 Coffee Maker
Our office is relocating and I need to prepare our Bunn coffee maker to be moved. It appears to be working fine now, but we do live in a hard-water area. So: - Obviously we will be unplugging it. Can it be emptied? If so, advice on how would be helpful. - If it can be emptied, the set up at the new location should be the same as initial set up (I have those directions.) If it can't be emptied, should we just plug it back in and wait for it to heat up? - It also will certainly need significant de-mineraling. Any advice besides using the de-scaler device [long spring-like thing]?
    Problem Solver:
  • 8 Answers
I work for BUNN. Yes, you can empty it - here's a link to instructions http://www.bunn.com/retail/service/faq.html#faq6
Also, it's absolutely a perfect time to do the Periodic Cleaning of your brewer - here's a link to instructions for using vinegar to thoroughly clean your brewer. http://www.bunn.com/retail/service/cleaning.html
If you want to move the brewer without draining, please be sure to unplug it and let the water cool for about 6 hours before moving it (the water inside is 200 degrees). Then, when you get to the new location you can just plug it in and let it heat up.
Any other questions, please let me know. lisa.mccloud@bunn.com
Posted on Feb 01, 2010
Testimonial: "Thank you! That's exactly what I needed to know!"
What is the best way to remove lime scale and other mineral build up from a Bunn VPR coffee maker? Water flow has been reduced to a trickle even though we used filtered water.
I always use CLR to clean my coffee maker. You don't need much more than 1/4 cup and mix with 8 cups of water and brew it like you would make a pot of coffee, then dump it out and run 2-3 more pots of just water, that should work fine. Also, run vinegar thru the machine once in awhile to help keep it clean
Apr 13, 2010 | Bunn VPR Coffee Maker
The water is boiling, but wont flow into the filter??
Remove sprayhead and pour water into tank until it flows from the brew tube, then replace sprayhead and brew coffee.
Mar 14, 2010 | Bunn VPS Coffee Maker
Sparking and spraying water out back
Remove the top panel, and then the pan like basin(big nut in middle, Make sure you keep gasket under basin in good condition. That should give you a starting point for your repair.
Sep 28, 2009 | Bunn VP17-3 Coffee Maker
Bunn coffeemaker steaming and bubbling over when OFF
You need to replace the thermostat and the hi limit switch punch up bunnomatic.com and get partsthis machine is good for many years
Jul 22, 2009 | Bunn VPR Coffee Maker
Water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Jun 02, 2009 | Bunn GR10 Coffee Maker
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Bunn Coffee Maker Not Working
Tammy,
Plug the coffee maker in and fiIl with water again and let it flow through. Do this several times.
I don't think household bleach would cause any damage to the unit. Industrial bleach, yes, but not household, especially if diluted with water.
Let me know what you find.
Jan 28, 2009 | Bunn NHB Coffee Maker
Bunn BT10-B silicone washer
Yes, you can get a washer from your local Bunn repair shop. For a list of repair facilities in your area, go to www.bunn.com And yes, the heat is a problem, so you can't use just any washer.
Jan 24, 2009 | Bunn BT10B Coffee Maker
Bunn GR10 Coffee Maker Logo
140 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
