Question about GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket
Washer seems to need more water.
Whenever I wash my clothes in my Profile Harmony washer, there never seems to be enough water. The clothes are all wet and swish around, but there is never water covering them and it seems that at times they just stay in a big wet clump and don't get opened up enough to wash good. I don't feel like enough water is being dispensed. Can I control that? Thanks!
  • 6,784 Answers
HI, the water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Posted on Feb 01, 2010
There is only enough water to cover the clothes in the washer on the wash cycle, is this normal
Hi Judy, This is quite normal for modern machines. It's an eco friendly thing.
Jul 12, 2015 | Washing Machines
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
The spin cycle on my GE Profile Harmony washer has gone violent, what can cause this?
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
Nov 29, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Two problems . . . . 1) the detergent dispenses into the wash but when I go to do the next wash, the place where I put detergent in is filled with water????? 2) the washer doesn't seem to be putting enough...
You may have sediment in the valve screen or the valve just won't open completely. In either case i suggest replacing the valve. Your 2 problems are both associated with low flow from the water valve.
Mar 04, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Not enough water to wet all the clothes.
Either the water level switch has bad calibration or the water level tube has lost its air seal and needs to be refitted and air locked. If you do not know how to go about these tasks, call someone with experience. Goodluck, Macgivor
Jan 16, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Spinning water out of clothes
not spinning all the water out of clothes
Dec 29, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Black residue is getting all over clothing, every load. what is the problem? it's almost like some sort of shavings like off a piece of rubber or something. could it be a seal or something breaking...
Try checking the gaskets where the hoses connect to the water supply and the washer, I have found when they start breaking down they can sometimes almost melt onto the clothes.
Oct 31, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Foul water odor after wash
There is always a littlee water left in the sump of a washer after it is emptied. If the washer sits unused for as little as 2 or 3 days it can have that odor. One thing that I do is add about 1/4 cup of ammonia after the washer is full of water. DO NOT USE AMMONIA IF YOU USE BLEACH IN THE SAME WASH!!! IT WILL CAUSE CLORINE GAS TO BE RELEASED!! If bleach was used in the previous cycle it will be ok.
Feb 28, 2008 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket Logo
114 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
