Question about Braun Coffee Maker - 10 cup
I dropped my Braun electric toothbrush and it came apart. I have two washer looking pieces, 1 is a very thin circular rubber washer and the other is a brown flat fibre looking washer and don't know where they go. The wires are still attached to the battery. I have tried assembling the bits but when put on the charger the green light doesn't come on and it doesn't appear to charge. There is residual charge in the toothbrush and it does work when I push the plastic pieces attached to the white casing on the inside. Any ideas? V.
    Genius:
  • 2,052 Answers
Buy new one.
Good luck
Mai
Posted on May 10, 2017
4 Suggested Answers
  • 833 Answers
SOURCE: Braun espresso machine replacement part
call www.smallappliance.com They stock many parts not on their site.
Posted on Dec 05, 2007
  • 8 Answers
SOURCE: replacement parts for Braun 3062 espresso machine
Google Braun 3062. They are offering all kinds of parts
Posted on Dec 30, 2007
SOURCE: Braun Toothbrush repair?
I've just opened up and remounted my Braun toothbrush, an Oral-B model I think.
Your description corresponds.
Order for re-mounting:
Coil, rubber/soft washer, hard washer, spring, ...
The spring has no electrical use: I think it is just used to keep pressure on the washer and improve seal-ness.
The coil has 2 electrical ends, which connect to each (narrow) sides of the small PCB. One of the connections happens to touch the battery holder.
I wanted to replace the battery, but gave up as the battery seems so hard to remove: I don't see how to replace it without destroying everything.
Also, the format is larger than an AA.
Any idea?
Olivier - Belgium
Posted on Feb 28, 2008
How to disassemble a Braun 5742 electric Shaver?
shaveroutlet.com has a video for this. See link below
http://www.youtube.com/watch?v=v_XsmqA_YTk
Feb 05, 2014 | Braun 4775 Electric Shaver
Electric rechargeable braun toothbrush 500
I had the same problem at the beginning of the year. I think i had bought 3 electric tooth brushes and all seemed to cave in within a couple of weeks. My friend recommended going to Macy's to buy one, which I did and it is still going strong. Maybe you charged it for a very long period of time and it overheat the system circuit? I'm not sure but I would recommend getting a new toothbrush.
Jul 04, 2012 | Oral B Braun B Professional Care 500...
3756 f 136 manual
The User Manual for the Braun Professional Care 500 Electric Recharegable Toothbrush can be found line here:
http://www.service.braun.com/line/OC/O3756/O3756_14_MN.pdf
Should this be helpful, please rate my assistance.
Thank you!
Jan 09, 2012 | Oral B Braun B Professional Care 500...
I have purchased a Braun proffessional care electric toothbrush and cannot charge it. I have tried three different plug adapters. I have changed the toothbrush at Boots 3 times. I have tried to charge it...
Your electrical socket may be wrongly wired, with polarity mixed up. Try another socket. Also, some electric toothbrushes need to be "off" to successfully charge. Maybe the flasing red light for 10 seconds is telling you the toothbrush is "on" and not accepting charge.
Sep 12, 2017 | Oral B Braun B Professional Care 500...
My mom's Kenmore HE3 Elite electric dryer vibrates rapidly while operating. She was cleaning out the lint catcher area with a toothbrush and dropped it inside, then decided to run it after several failed...
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
Mar 22, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to reconnect the copper cables in braun sonic
If you look closely, it doesn't much matter, because they are all twisted together when it is reassembled. Mine had two on the center and one on each end.
Aug 02, 2009 | Panasonic Sonic-1 ES 364 Electric Shaver
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The On & Off Switch does not work!!!!
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Aug 01, 2008 | Braun Syncro 7526 Electric Shaver
Braun SynchroPro 7526
Apr 03, 2008 | Braun Syncro 7526 Electric Shaver
Any idea?
Olivier - Belgium
Feb 28, 2008 | Braun Tassimo Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
375 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
