Question about Linksys Wireless-G WRT54G Router
Iam trying to add a wireless laptop to my network and the easy link says broken connection and will not leat me do any actions so I can add a computer
  • 2,260 Answers
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Feb 01, 2010
Compaq 610 windows 7 is unable to detect network
Click on the "Start" menu and selecting "Control Panel."Click on the icon that reads "hardware and Sound." Then, select the tab that reads "Bluetooth Devices." Click on the "Add" button. This will put your computer in "Search Mode." This means that it will search for any compatible Bluetooth devices in the area. Put your Bluetooth device in "Discovery Mode." This can be done by pressing and holding the button on the side of the device. This will cause the device to send out a signal that will be received by the laptop computer.
Select your device from the list of found devices on your laptop. Once this is done, your laptop and Bluetooth device will be permanently connected as long as they are both turned on.
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Jan 21, 2013 | HP Compaq 610 T5870 156 WH248UTABA...
I have IBM Thinkpad R52 & Compaq Presario V2000 Notebook pc. Iam using windows xp on both but whenever i trying to connect wireless network its showing "windows unable to connect the selected...
To connect to your wireless router, the router's wireless settings needs to be configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 03, 2011 | Computers & Internet
I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
2.Right-click the Wireless Network Connection, and then click Properties.
3.On the Wireless Networks tab click Add.
4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
6.Click OK and your home network will be added to the list of preferred networks.
if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
Aug 25, 2010 | D-Link (DI-784) Wireless Router
Do i need to install the d-link wbr-1310 to my new laptop to get it operational. it indicates that there is a wireless connection but is requesting additional information.
I think you have windows vista on your computer. When you try to connect to the wireless network it will ask you for additional log on information. I believe you wireless network is secured. You don't need to install the router on your wireless laptop. All you need to do is connect to the wireless network. First check the wireless settings of the router. Once you get the wireless settings on the router, add the wireless network manually.
Click Here for step by step solution
Mar 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How do I protect my connection from unauthorized access.
Hello, David.
The best way to protect your wireless access from unauthorized access is to add a password.
Without a password, if someone drives by your home with a laptop, etc. and sees your network, they can connect.
If you are uncertain about how to add a password, contact your provider.
Hope this helps.
Nov 05, 2009 | D-Link DIR-615 Wireless Router
Not able to connect wireless networks from my T42
What exactly is it doing when trying to connect at home?
Jul 30, 2008 | IBM ThinkPad T42 Notebook
Wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Jul 05, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Printer Pinging problem?
Make sure your wireless workgroup/domain are the same as your wired network. If they are, you should reinstall the printer from control panel. Choose add network printer, choose the proper workgroup/domain, you should see the available printer, select it, it may need to download drivers and install them. Tim
Jan 29, 2007 | HP Color LaserJet 2600n Printer
Linksys Wireless-G WRT54G Router Logo
54 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
