Question about Sharp R-1460 Microwave Oven
Sharp Microwave oven controls do not work
Just happened! I close the microwave oven door, motor runs, canot turn the table on or off. It stops when I open the door
  • 1 more comment
  • adrjgr Feb 19, 2008
    I found the problem this morning. The upper door switch had broken loose from its holder, i. e., the plastic piece holding the switch in place broke. I was able to get the switch stabilized in place and the microwave oven is now operational again. Thanks for everyones interest. This is a great site.
    adrjgr
  • Anonymous Mar 05, 2008
    When I close the door the motor runs (the turntable does NOT turn). It stops when I open the door. I can not program any functions, i.e. change time, hit two minutes to cook, put in a power level, etc. I have a Sharp R-1461. Any suggestions?
  • Anonymous Feb 13, 2009
    I close door , microwave runs without turning on. only shuts off when I open door. How do I get to the latch holder to repair it. According to one other note on this web site the person re-attached locke holder. Can you assist in instructions on how to grt to the mount that holds the switch
  • Sharp Master
  • 9,086 Answers
You mean the turntable motor turns whenever the door is shut, even if you're not cooking?
If that's the case, then the problem would probably be a stuck relay (RY3) on the control circuit board, which we regularly repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you have a different problem than I described, please reply back with details before you give us your rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 19, 2008
  • William Miller
    William Miller Feb 19, 2008
    Right! These can be hot-glued if you don't want to go to the trouble of replacing the door hook (switch mount).
    If you use any glue, the surfaces have to be squeaky clean and dry.
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Turn table stop turning and wont heat
Your oven has a couple of switches inside that are operated by the door latches. One of them controls the power to the turntable and magnetron tube power transformer. The switch is either out of adjustment (which can happen if the oven door gets closed real hard) or is bad. I would suggest letting a professional check the oven and repair the problem. Door repairs have a direct effect on microwave leakage and it's better to have them done safely.
Dec 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave will run for a minute and then shut off
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp (and Sharp-made Dacor and Wolf) models stop after 59 seconds.
See: http://www.fixya.com/uploads/Howto/B27054B.jpg
Nov 29, 2010 | Dacor DMT2420SS Microwave Oven
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
