Question about Microwave Ovens
My microwave oven( a Twinbird), will stop suddenly
My microwave oven( a Twinbird DR-4215; 60 Hz), will stop suddenly when operating under normal conditions, then start up again on its own. It does this inconsistently, but fairly often recently. What do you think the problem is?
SOURCE: Maytag Over the oven microwave
posted by Watsonism on Dec 29, 2007 Report abuse
I have model # MMV5000ADA ,13.5 amps, watts 1450, vac 120, HZ 60, DHHS code No. H7NF Manfactured in Cleveland, OH in April 1998.
My problem started when I was defrosting some fish. I turned on the light under the hood at the same time and I got a bright flash from the light unit and the microwave stopped working. I believed that both lights had blown. Since then, I have attempted to replace the lights { I get no response}. When I start the microwave, I get a humming sound and the food does get hot, but it is not evenly heated. Also, the vent fan is not working. No circuit breakers were tripped and all other operations on the microwave keyboard continue to function except the light switch. I have unplugged the microwave for several days and then attempted to operate the microwave with the same results. I have defrosted meat before and turned on the lights simultaneously, but I this never happened before. The turntable is not working, but the vent fan settings [high & low] both work when I turn them on manually.
Posted on Dec 31, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Ariston Wall oven FM87F
I would consult the owner's manual, but normally no.
The controller is dependent on getting the proper 50Hz (or 60Hz, depending) signal to assure proper operation.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Dual Wave II microwave oven blowing fuse
It sounds like a shorted high voltage capacitor, a fairly cheap fix. But if it's good, I would suspect the high voltage transformer.
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: instructions for Sharp R953 900wt jet convection grill microwave
Info on ordering SharpUK parts / spares is here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
Posted on Dec 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: LCD panel dimly lit, microwave works fine.
You have two options for this model:
We can repair your control unit for $39.95 in about a week or you can order a modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
Motor is noisy, oven vibrates and oven is not heating; this is a sudden change from normal operation.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
May 29, 2011 | Emerson MW8777W Microwave Oven
It suddenly stopped working correctly. It makes a strange noise when operating and doesn't heat food.
heatman101
Sep 16, 2010 | Sharp R-1850A Convection/Microwave Oven
Our microwave suddenly stopped operating.
Inside is a fuse. It is probably bad.
Jan 19, 2010 | Microwave Ovens
Microwave stopped working all of a sudden. NO power supply. I tried placing at different places.But no use..I ddidn't see any problem before it stopped working..
the most common problem with microwaves is the door protection circuit blows a fuse. the door catches operate switch that if they do not operate correctly( normally after the door has been slammed). the good part is they place the fuse inside the casing. so remove the power open the casing( several screws) and check all the fuses in side.
Feb 19, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Samsung MD800SC Microwave runs but stopped heating
Chances are you have a bad connection, maybe the cook relay or at the magnetron, but feel free to write back with details when it fails again.
Aug 19, 2008 | Samsung MD800SC Microwave Oven
Jun 18, 2008 | Microwave Ovens
is the turntable working
Dec 29, 2007 | Microwave Ovens
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
