To connect your PC or Laptop to your Harman Kardon AVR 2600 you need to connect the HDMI cable output of your graphics card to one of the 4 HDMI inputs on the AVR 2600 receiver. The HDMI connector on the AVR 2600 labeled "HDMI Monitor" is on output and cannot be used as in input.
You need to select the corresponding input from the front of the AVR 2600 or using the remote. Next you need to make sure your have the HDMI output port selected on hour graphics card. This will probably not apply to your PC, but may require some settings from the function keys on your Laptop.
Note that you will probably need to also connect audio from your PC to your receiver as well. I would recommend you use HDMI cable with ver1.4 specification so that you have the best chance of getting audio over the HDMI. If you only get video, then run separate Toslink (optical) or RCA cables to get the audio to the system from the PC.
THAT would depend on the unspecified audio outputs of your PC. Access the controls for the Sound Card and make sure they're turned on and up, then cable whatever it has to something on the Denon that fits it. Neither device knows or cares that the other is anything more or less than a standard audio device or self-driven speaker set.
do you get sound from any input even static from am/fm this is the same receiver i have and had to replace the board on it. hope that helps let me know
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
probably your AVR card is burnt...
an AVR card is located right outside the stator...looks just like an AK-47 clip (i don't know how else to describe it)...i put a pic below this.
replace it and check again
AVR location
AVR card
