Question about HP Pavilion dv4000 Notebook
Hp pavilion dv4 left buttom not work
I've a hp dv4 laptop. The left button not work and the touch pad no longer acknowledges that i'm tapping on it but the cursor moves on the sreen i download the mouse driver and the problem persist. Somebody who help me with this problem thanks
  • 152 Answers
Left click is membran switch it was fix in motherboard
need to replace it .
for tapping control you can set as per your comfort from
start menu ---> setting ---> control panel ---->mouse
in "Buttons" tab select double click speed and check it right side yellow folder open and close when you tapping
Posted on Feb 01, 2010
What is the tiny orange light about in the left corner of my HP pavilion key pad ?
"You can double-tap a dot in the top left corner of the touch pad to disable it; a small orange light will appear to indicate that it's turned off."
Mar 01, 2011 | HP Pavilion N5495 Notebook
The touch pad its not working properly on my hp pavilion dv7
my buddy brought his to me last week with this problem he could move the curser but had to hit the button to left click when he tap on the pad it did nothing you may have changed the configuration in Synaptics Touchpad you may have diabled certain settings in it i usuallu has a icon to the bottom right near clock it should be a red symbol it might say Synaptics pointing device when you but cursor over it
Sep 02, 2010 | HP Pavilion dv7-1240us Notebook
My Hp Laptop's touch pad is not reponding to touch. Please help me. The curser reponds but not the touch reponse. The touch pad reaponds to scrolling but not to finger tappings. The two right and left bars...
there is a key combination that enables/disables the touch pad. it's the Fn key + the function key that shows a little mouse icon in blue at the top of your keyboard. on Fujitsu this would be Fn+F6 for instance. if this doesn't work, it is possible that the touch pad has been turned off in the BIOS setup. you will have to enter the BIOS and enable or automate the "internal pointing device"
Apr 21, 2010 | HP Pavilion dv6000z Notebook
Mouse pad's not working
HAVE YOU REDONE THE DRIVERS IF PRESS ON THE PANEL AT TOP OF PAD DOSE WORK IF IT IS A BORD PROB SAME AS HP NX6110
Jan 31, 2010 | HP Pavilion dv4000 Notebook
Hey My touch panel aint working
there is a button at the top of the touch pad with a light to the left, blue means its unlocked, orange means its unlocked. try the button to swap between states
Jan 12, 2010 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Loose left button mouse on an hp dv4-1120us
If only the one button is loose then touch pad assembly probably will require replacement. This isn't a big job but usually involves opening the case. Two screws and one connector and button it back up. If the laptop is new you should have this covered by warranty. Cost of the part should be about $30-$70 as well as labor.
If you are lucky you might just have a loose fitting button that you can snap back in to place. With the laptop off try to gently push/wiggle the button down. It might pop back into its mounts. If this works (slight chance) then it might work normally for a while and pop out again. It won't have fixed the wear that let it come loose.
Aug 17, 2009 | HP Pavilion DV4-1120US Laptop
Touch pad not working
Go to device manager
Right click the touchpad device
Uninstall driver
Reboot system
go here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-66690-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795289
Reinstall touchpad driver
see if that helps
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Jul 01, 2009 | HP Pavilion dv4000 Notebook
How do I disable double-click on an HP Pavilion dv4 touchpad?
Hi there Dublin. I recently bought a HP laptop myself, and I believe I can help your situation, or at least I hope I can. Here's what you do: Access your Control Panel>Click Mouse>Click Device Settings>Click Settings> Click Tapping> Click Disable Tapping. That should do the trick. You are not disabling your touch-pad, just the double-clicking that is associated with it. Drove me nuts for about a day, 'til I figured it out..Hope it worked for your notebook.
Apr 06, 2009 | HP Pavilion dv4000 Notebook
Left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Dec 30, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
503 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
