Question about Maytag MMV4205 Microwave Oven
No power- Outlet o.k.
Mmv4206 how do ypu check the fuses
What kind of reaction would happen if the microwave were pluged into an out let that the wires were revered on the outlet. would the led light up, would it damage the microwave, could it be repaired?
Posted on Jul 08, 2008
  • 958 Answers
Open the housing, screws are on the back and sides. you can see some fuses there. check for continuity
Posted on Feb 19, 2008
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
No power checked outlet and power is on
HELLO.
This is the way out of the problem.
The outlet is on power,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
Thanks .
SERIAL # 20101639 RELEASED 2002 THIS MAGIC CHEF IS USED IN AN RV FUSE BLEW RESET MAIN FUSE MICROWAVE DID NOT COME ON PULLED OUT CHECKED POWER OUTLET AND POWER IS WORKING TO OUTLET CHECKED ON ANOTHER...
most microwaves do have a fuse to protect the power supply .outer cabinet has to be removed and then you will be able to see it . look where the power cord comes into cabinet
Dec 01, 2017 | Magic Chef MCM660A Microwave Oven
Our Maytag microwave died. The outlet has power.
you have to remove the cover, un-plug the power cord=
un-screw the screws located behind the unit and on the sides if any also under side if any, remove cover and you will locate the fuses and other components behind the key pad, also check slow blow or thermal fuse usually located on top of oven. NB: HIGH VOLTAGE COMPONENTS PROCEED WITH CAUTION!!!!!!!
Mar 25, 2010 | Maytag MMV4205 Microwave Oven
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Sep 10, 2009 | Samsung MS1040BB Microwave Oven
Lost power to microwave have power to outlet is it a fuse and where would that be
What i will tell you concern only certified technician. do that to your own risk .
Unplug the microwave oven, open the cover , then follow the cable from outlet, you will check that cable with meter , if that cable is good , you will see a fuse inside attached to one of the power cable. Check again this with ohmmeter. ...
Aug 30, 2009 | Microwave Ovens
Maytag MMV4205 Microwave Oven Logo
107 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
