Question about Canon PIXMA MP510 All-In-One InkJet Printer
Black and wihte print - Canon PIXMA MP510 All-In-One InkJet Printer
  • 4,041 Answers
Hi Yes you can try clean.
I see this lots on the posting so try
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 02, 2010
I HAVE A PRINT CARTRIDGE ALIGNMENT problem wiht my HP C7820
Try to find the alignment software in your HP printer's Control Center. If alignment does not work, you could un-install the HP printer software and drivers. Disconnect the printer from the computer. Restart without HP software, drivers, and printer. Shutdown. Now reconnect the printer and turn the computer back on. Re-load HP software and drivers. Follow there direction as you go. You'll be asked to align the printer.
Sep 02, 2012 | HP Photosmart C7280 All-in-One Printer
I have a laserjet Hp 1600 and it is printing out wiht red and green lines around the images? What can I do??
Try restarting the computer and printer
Try running printer alignment in the hp software that comes with the printer
Trying removing and reinserting the ink cartridge
May 11, 2011 | HP LaserJet 1600 Printer
We use 2 column lables and when we print the barcode on the second side will not scan. there is missing lines in the barcode.
possible, need printhead replacement. Try to.
Turn printer off,
press pouse button,
turn printer on, still pressing pouse button for 10 seconds, and then relese the button. the printer will print the pouse test with barcode, check if coming with wihte lines across, if yes, change printhead.
Mar 03, 2011 | Zebra Z4Mplus Label Printer
Screen is black wiht a single 1/8 thick horizontal line across entire screen. Sound is ok. Other TVs are working.
cold solder in vertical ic and check caps around to..if you see resin around any cap, change.
Apr 22, 2010 | Toshiba CF32H40 32" TV
How to make change to print on thermal paper
On the front panel of the printer:
Press SETUP/EXIT
Press NEXT/SAVE until you see a setting call PRINT METHOD
Change the setting from THERMAL TRANS to DIRECT
Press SETUP/EXIT
Press NEXT/SAVE to make a permanent save
Hope that helps.
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
HP leserjet printer, keeps printing
Sounds like a driver glitch, or wrong driver to me, try re-installing it
Mar 17, 2009 | HP LaserJet P2015dn Printer
Blank/black screen
Your CD drive is bad or its the videocard gone out at that exact moment you had the CD in.
Aug 02, 2008 | Compaq Presario 1200 Notebook
Machine Error AF
plz check the flat cables silver ends! It might be that the flat cable has a broken cable. Clean contact on main board and flatcable side with some electrical cleaning solution.
But i guess you have a broken cable.
AF only appears when scanner is not connected to machines circuit board. In case you wont find a broken cable, buy a second hand dcp 110c and use this scanner as a spare-part.
Feb 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
old marine
old marine
