Question about Desa International Reddy Heater 200,000 BTU Kerosene Forced-Air Heater #R200BT
Heater shuts off gives a puff of smoke - Desa International Reddy Heater 200,000 BTU Kerosene Forced-Air Heater #R200BT
    Champion:
  • 225 Answers
It is to low on fuel
Posted on Feb 05, 2010
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Reddy repair center
There is likely some water in the tank. Completely empty and flush the tank with clean fuel.
The unit won't run with cover on. Fan stsrts and
Its not getting enough air to burn with the cover on. See if you can figure out how to adjust the air flow.
May 02, 2010 | Reddy HEATER RH125T 125,000-BTU...
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Desa International Reddy Heater 200,000 BTU Kerosene Forced-Air Heater #R200BT Logo
80 people viewed this question
Top Desa International Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Desa International Measuring Tool and Sensor Expert? Answer questions, earn points and help others
