Question about Dell Inspiron 1525 Laptop
Dell laptop is not typing apostrophes unless I mash the key and hold for a long time -- solution?
    Guru:
  • 194 Answers
The keys of a laptop are held above the pressure sensors by two plastic pieces over a piece of rubber. If one or both of these are damaged, you will not be able to properly use your key, and it will take unusual amounts of pressure to make it work. I would suggest either switching to a USB keyboard or ordering a replacement keyboard from Dell. Replacing the keyboard is not an especially expensive or difficult process, and I would be more than happy to share a How To on how it can be done with ease. Hope this helps.
Good Luck,
NOLA Tech
Posted on Feb 01, 2010
Sony vaio VPCEE2M1E
Configure your keyboard to the correct country code and then run a registry cleaning programme to help with the start up.
Dec 01, 2013 | Computers & Internet
How can i type latter Apostrophe with dell laptop
Apostrophe key is next to the enter key
Aug 07, 2012 | Computers & Internet
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
Can't type: hello folks... my Dell 630m won't let me type or click unless I am holding the shift key. When I turn it on the machine makes a beeping noise (sometimes one beep, sometimes 20 ) before Ubuntu...
Sounds like a bad keyboard.
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 20, 2010 | Dell Inspiron 630M Notebook
Inpspiron 1525 dell
It's probable you're inadvertently touching the touchpad with another part of your hands while you're typing. There's a setting in the touchpad configuration where you can choose to sort of disable the touchpad while typing. Regarding the trouble keys, there are keyboards that come deffective from the factory. The one I'm using this moment has that problem with just two keys, reason why I can still put up with it! If your notebook is still under warranty, call DELL and arrange service for it.
Aug 16, 2009 | Dell Inspiron 1501 Notebook
Blue fn button
you have the number lock on... tap the fn and nm key at the same time to shut it off....
Robert
Please take a moment to rate this solution thanks
Jan 30, 2009 | Dell Latitude D600 Notebook
Cannot get apostrophes or question marks
I just figured this out. Hold down your left shift key, then press CTRL. It may take a couple of times for it to work, but it will eventually.
Oct 08, 2008 | Compaq Keyboard
Dell Inspiron 1525 Laptop Logo
290 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
