Question about Hobart A200 Stand Mixer
Hobart mixer i would like the electrical part for the interior motor of a hobart mixer model a200,by any chance would you guys have this part?
  • 640 Answers
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Posted on Feb 19, 2008
How to invert motor turning direction?
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
A200 Hobart Service
Apr 06, 2016 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
Feb 23, 2009 | Hobart A200 Stand Mixer
Speed reduction of Hobart A200 mixer
Hi Don. If your mixer is hurling honey, you must be very popular in the ant world...Sorry!
The Hobart electric motor on your mixer was designed and engineered to operate on 115-120 volt current and is the most dependable, and capable commercial mixer out there Is it possible for you to use a commercial Imerssion Blender for the first part of your mixing operation. Once your honey thickens a bit perhaps the a200 wouldn't hurl honey. Another consideration would be to either try a different beater or modify the one you have by removing surface area from the beater. If you remove metal, be sure to do it in a balanced fashion to avoid unwanted vibration in the beater. If you're not up to removing metal, take it to a machine shop and they'll do it for you. It probably won't take long, or cost much, and they have the expertise and the equipment to do it properly. If you found this solution helpful, please rate it. Good luck! ricardok45.
Feb 02, 2009 | Hobart A200 Stand Mixer
Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
Aug 21, 2008 | Hobart A200 Stand Mixer
Manual for Hobart Mixer A200
You can go to hobartcorp.com and register for free then you can print or download a parts
manual to help you to do repair. Hobart provide service manual to their technician only.
May 05, 2008 | Hobart A200 Stand Mixer
Motor replacement for A200
If the motor runs and when under a load the planetary stops its not the motor.You either have a sheared key or broken gear in the transmission.
Mar 22, 2008 | Hobart A200 Stand Mixer
Same speed
I believe the speed control needs to be replaced. It controls how much electricity is sent to the motor.
Jan 28, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
213 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
