Question about Brother GX-6750 Typewriter
Broken Dazy Wheel
My dazy wheel is not turning. When it does turn it is only when you hit the white-out button. It also only prints when you hit the white-out button.
  • 398 Answers
The "Carriage Lift Gear" is either broken or out of sync. This is quite common problem. Unfortunately this is not something that someone without training can fix. I just to do this repair in 30 minutes but of course the owner charger for a full hour.
Posted on Mar 14, 2008
The nakajima ae610 types two vertical lines instead of letters
The print hammer is striking between the letters. Two thing
you may have a petal, letter broken off. If its the same letter every time usually thats it, need new daisy wheel.
Or Homing is off when the wheel turns hammer hits between letters. Needs repair.
Or
Daisy wheel petals are bent.
Dec 12, 2016 | Nakajima Office Equipment & Supplies
Print wheel hammer not hitting print wheel when typing.
Your problem is probably the print solenoid either not firing or the cap that is on the end of it has broken off. Usually the cap is broken and a new one can be installed in its place.
Jan 07, 2014 | Lexmark Wheelwriter 1500 Typewriter
How do I set time on a 4Gb Sansa Fuze?
Press the MENU button to bring up the main menu. "Turn" the command wheel to select "Settings" and press the central button. "Turn" the command wheel to select "System Settings" and press the central button. "Turn" the command wheel to select "Date & Time" (it's not initially on the screen, the screen will scroll when you hit the bottom) and press the central button.
Select the desired field by "turning" the command wheel and either press the central button or click the right side of the command wheel. Change the field by "turning" the command wheel. When you have the field set properly, click the left side of the command wheel and you can then select another field.
When done, repeatedly click the left side of the command wheel to back out of the menu system.
Apr 26, 2011 | Audio Players & Recorders
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
The wheel on the Wheelwriter 5 turns when the keys are hit, however, it is does not strike the paper?
The plastic print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DicyO
Cleveland Business Machines
216-241-0027
Jan 06, 2011 | IBM Office Equipment & Supplies
IBM wheelwriter 6 turns on and everything works...but the striker doesn't hit the print/wheel letters
The print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00
DickyO
216-242-0027
Jan 15, 2010 | IBM Office Equipment & Supplies
80 GB Ipod Classic shows locked and click wheel not working
Slide the switch on the top of the ipod to where it shows white instead of orange. If it is already off hold, then you may have a broken hold switch.
Aug 10, 2009 | Apple iPod MA446LL/A MP3 Player
The front not straight when driving
Its probably bent or broken one of the tie ends on the steering. Ring your nearest suppier they will pick it up and repair it.
Apr 14, 2009 | Agri-Fab Agri Fab Spreader
When typing, a letter is hit but a number is being printed. Typewriter is a Brother CE-500 model. We think you need to use the "Code"function but the manual has been missing for some time
Turn typewriter off, hold down CODE, turn machine back on.
Make sure you are not set for PROPORTIONAL SPACING.
Remove print wheel, turn machine off, reinstall print wheel, turn back on.
Nov 25, 2008 | Brother Office Equipment & Supplies
Print Problem
Could be 2 things:
Either the 3rd digit of the number wheel is sticking or the solenoid for the 3rd digit is dirty, stuck or bad.
You can take the cover for the paper and see if the wheels are turning. Enter all 8888888888's and keep hitting +, this will make all of the wheels turn. If the 3rd digit isnt moving, then you can try to take a very small drop of light weight machine oil on a small flat tip screwdriver, and place a drop on both sides of the wheel that is sticking.
Enter all 8888888888's again, and keep hitting the + and see if it gets any better or starts to move.
If the wheel doesnt turn at all, then the solenoid might be stuck and it will be a lot harder to reach to service it.
Nov 18, 2006 | Monroe 7130 Calculator
Brother GX-6750 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
