Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I have an old kenmore washer and last week it was making some real strange noises now it won't spin??
  • 15,935 Answers
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Hello, My Kenmore Model #11042822203 Front load washer stops after water goes into the drum. It makes a straining noise. It spun last time I tried it, but went slower than normal.
This could be a lot of things. There is a belt drive on the drum, The belt might be worn out, there could be a bearing that is starting to fail or it could be the motor or motor control board. Kenmore Washer Won Spin
Jul 08, 2017 | Kenmore Washing Machines
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore washer started making banging noise in last spain cycle. Now unable to spinn drum by hand.
Having same problem with my Kenmore 500. Tomorrow will be the second time a repair man has visited the house. Washer on 5 weeks old. Drum bangs every other load. Load not unbalanced. Avoid this washer, it is a POS.
Mar 20, 2010 | Kenmore 24902 Top Load Washer
Front load Kenmore washer is not spinning and draining. Is motor burned out? It had been making a funny noise while pumping water out the last few weeks
if its still washing, then,,,, no!
but i do think the pump has become blocked up
have a look at the filter first clean it if blocked up
Oct 23, 2009 | Kenmore 44102 Front Load Washer
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
I have Kenmore 80 washer and for the last few weeks it has been making louder noises with a little whinning sound during the spin cycle, now it simply will not spin, but it does make awhirring sound on the...
first off empty the washer and check the 2 belts about a foot, from the bottom,to see if there still intact,,,also could need some grease to free up seized parts...gl
Mar 28, 2009 | Kenmore 22422 Top Load Washer
Washer does not spin or agitate at all. Timer works.
Check your belt. It may have become loose.
On the top right and left of the front panel insert a putty knife about 3 inches in where the top meets the front panel.
This will release the front panel so that you can see the motor and belt operation.
Better still, a 5 month old machine call for factory authorized service.
Feb 24, 2009 | General Electric WBSR3140GWW Top Load...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
