Question about ASUS WL-500g Wireless Router (WL500GDLX)
How to setup the wireless
I try to setup the wireless for my iphone. But it seem not working. the plug internet had no problem. I want to ask how to setup the wifi. Thanks
    President:
  • 239 Answers
Ok, just to check. Sometimes it is required for router to be in pairing mode, depends on router. So just check to see if there is a pairing button and if so give it a press then try this.
Go settings, Wi-Fi and select the network you want to connect to (tap the network text, not the blue arrow on the right).
The iPhone will then ask you for a password. Check underneath or on your router and you will see a long wireless key with various characters in it.
Depending on your system enter into the password box the first 5 or 13 characters for non-hex, or the first 10 or 26 characters for hex. Mine is the first 10.
Then click "join" and the small Wi-Fi fan should replace 3G.
Any further problems please post me back and I hope this helps ya.
Jim
Posted on Feb 10, 2010
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
I'm trying to connect to the Internet on another computer using my Internet tethering on my iPhone.... Usually I plug it in my computer and it comes up Internet tethering on my iPhone straight away with no...
Your other computer is expecting to see a wireless network, and the SSID is the wireless network 'name'. You probably need to reset this to go to the internet via your mobile rather than the wireless network.
Oct 15, 2010 | Computers & Internet
I have a WGT624 router. I have had verizon internet for about 2 months. Recently, I could not get on the internet using wireless but could when just using the modem. I have unplugged the router and then...
either you need to reconfigure the router for the wireless configuration or setup the router for PPPoE connection. if you have internet directly to the modem contact your router manufacturer if not then you need to contact your ISP and ask if you need to setup the route rwith PPPoE connection and get the user/password
Sep 07, 2009 | NetGear WGT624 Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Cannot get 2wire to work on my iphone! :(
Try this one:
>on ur WIFI networks, click "other..."
>then manually type in ur network name (if its set to default, it should be 2WIRE and the last 3 digits of ur SN. It is case sensitive so type the name exactly how it looks like.)
>make sure that the setting is set to WEP
>on the password box, enter a dollar sign/$ first and then the 10 digit code under ur 2wire
keep me posted on this one
Aug 30, 2008 | 2wire (1000-400106-003)
Ethernet Cord for Router?
I want to tell you that how can you get your password back or reset your wireless password.
1. Work on your wired computer which is connected with the netgear router using ethernet cable
2. Make sure on the rear side of your netgear router you can see four ethernet slots and one internet slot.
3. One internet slot is only for your ISP modem and rest of the four slots you can use any computer to connect with that using ethernet cable.
4. Click on start - Run - then type in "cmd" press enter and you will get black screen. under the black screen just type "ipconfig" you can see some information on your screen search for default gateway numbers.
5. Once you get default gateway open IE and type those numbers without anything else then press enter.
6. It will ask you for user name and password by default "admin" and password is " password "
7. Once you click ok it will open netgear setting page
8. On the left side you can see wireless setting which is under "setup" then click on that option
9. On the middle of the screen you can scroll down that page at the bottom you can see your security key or passphrase.
10. Or you can type new password on the same screen and apply those settings
11. Now try again to connect your device wirelessly enter you existing password or new password which you have setup.
12. Make sure one thing more on the left hand side you have option called "Router Status"
13 Once you click on that at the middle of the screen show you router status and you can find the option called "internet port"
14. We are getting ip under internet port
15. If we re getting ip address then you can simply try to connect wirelessly otherwise please run setup wizard to configure your router. you should getting ip under internet port.
I believe these steps help you to resolve your problem
Thanks & Regards.
Jaspreet Singh Saini
Aug 22, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Re: IPhone doesn't connect with wifi automatically - password not recoginized HELP!!!
Yep, I had the same problem with my iPhone as well (32GB 3GS).
Had the signal NO problem for about a week then POOF it was gone. WTF?
Prowled the boards looking for a solution.
Tried resetting the phone, resetting the Wi-Fi, switching airplane mode on and off, forgetting the network, etc.
HERE'S YOUR SOLUTION :
Go unplug your wireless router's power cord.
Wait 30 seconds.
Plug it back in.
Your iPhone will reconnect, and you'll be back in business.
Jack
Jul 15, 2007 | Apple iPhone Smartphone
ASUS WL-500g Wireless Router (WL500GDLX) Logo
110 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
