SOURCE: 1 burner wont stop clicking on miele cooktop km 344
usually due to the ignition unit being faulty. being miele, the part will be pricey. another solution is to take out the ignition unit and take it into a local electrical repair outfit and see if it can be matched up with one from a different make. to check if this is the problem, interchange two electrode leads on the ignition unit and see if fault changers to another burner. you sometimes find that there is a spare ignition outlet on the ignition unit and this can be used as an alternative
SOURCE: Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
SOURCE: Miele KM 342 - I have burner - will ignite when
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
SOURCE: The Miele KM326G cook top has 5 burners: 2 small
You could have a clog in your gas line. Have the gas company come out to check the pressure.
