Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister shampooer
I have the Rainbow E series shampooer all hooked up and when I turn it on no water sprays out. It seems like the shampooer pump is not working. I have checked the hose but it seems fine and the pump does not get warm from trying to pump
  • 1 more comment
  • Ben1949 Feb 23, 2008
    I have the same problem, I've used the shampooer once and it now has no water coming from the water line. Can't find any blockage.
  • jmccarty849 Dec 16, 2008
    water and shampoo will not spray out of my shampooer
  • zillamena Jan 03, 2009
    I have had my shampooer for 3 years and just hooked it up for the first time. No water will come out of the hoses which go into the hanfle and come out the other end. I can't see what is happening inside the handle and there is no way to open the handle and check the hoses for holes or cuts or blockage.. it will **** up water but won't put any water out .
    tjhooker22@yahoo.com
I have never used my rainbow shampooer and have had it 2 or 3 years it is not working it will **** up water but will not spray water or shampoo what do i do?
Posted on Dec 16, 2008
    the stars mean ****
  • 25 Answers
E series aqua mates do not use a pump only pressure from water supply <faucet> if no water is getting through the valve assembly is probably bad. which has no servicable parts, reccomend taking to local vac shop to replace valve assebly in handle. not an easy job and can damage more if you attemp to fix. rainbow parts not cheep so dont want to break more than need to.
Posted on Mar 26, 2008
How do i hook up the shampooer to my rainbow e series e2 canister have no instructions
Wow it's been a while. I think the shampoo attachment needs to be hook on the blowind part of the machine. If I didn't help take itto any vacuum store, they should be able to show you. Sorry thats the best I can give you. Chris
Feb 09, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Shampooer will not work on my e2 Rainbow. Help!
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Instuctions on how to use them together
youhook up the shampooer the same way you would hook up the vacuum head. you can put jut a little bit of water in the basin and it basically works like the vacuum except it dispenses cleaner and water when you posh the button in on the handle.
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Cant get rainbow shampooer to work
use the suction port for the vac hose
the water hose hooks to your kitchen faucet
Nov 11, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How to hook-up shampooer to faucet
you may need an adaptor to snap it on
can get them at a vac shop
Oct 14, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Shampooer
It's been while since I used one. Hopefully things haven't changed.
One hose has to be be connected to the faucet of the sink using the adaptor. The other hose is supposed to go to the Rainbow iteslf.
one gets the rug wet and the other extracts.
Jun 24, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Shampooer
aqua mates have an o-ringed valve assembly that go bad regularly reccoment having it replaced by local vac shop
Oct 07, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
698 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
