Question about Dell Inspiron XPS M140 Notebook
My 2 year old stepped on{or dropped } my Dell xps m140 and cracked the screen. I thought I would replace it myself..Before I do, I hooked up an external monitor to see if it still operates properly, well the windows Xp screen comes up but it will not boot all the way.? { Mother board? } Any suggestions
    Novelist:
  • 137 Answers
This error is also cause by the hard drive storage of your pc notebook, if you know how to locate the hard drive you just have to remove it for a while and then put it back, some loose connection of the hard drive cause the problem, if you find it still not working, you need to repair the system startup of Windown XP it is corrupted that's why it wont start.
Before attempting to check the physical parts of your notebook, try first to check and recover the Windows startup system.
In windows startup repair you can use the Windows Recovery Console.
Source: http://support.microsoft.com/kb/314058
Here's the step to start in Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
After you start the Windows Recovery Console, you receive the following message:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
1: C:\WINDOWS
Which Windows Installation would you like to log on to ?
(To cancel, press ENTER)
Enter the number for the appropriate Windows installation. In this example, you would press 1. Then, Windows prompts you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot be authenticated correctly. After you enter your password and the Windows Recovery Console starts, type Exit to restart the computer.
Use the fixboot command to repair the startup boot of your notebook.
Posted on Feb 01, 2010
My dell xps m140 keyboard is making double letters
Letters may be sticky. Did you drop coffee, soda or any liquid on the keyboard? Does the letter key "stick" and come up a second after you release it?
You may need to clean or replace the keyboard. To be on the safe side BEFORE you do it, plug a full size keyboard on the back of your laptop and check if the problem goes away.
Mar 21, 2010 | Dell Inspiron XPS M140 Notebook
Need drivers to run windows 98se on dell xps m140
Microsoft (and Dell) stopped supporting Windows 98 a few years ago -- it lasted for over TEN years! So, it is *NOT* likely that you will find drivers for any computer that was "designed for Windows 2000" or "designed for Windows XP" or "designed for Vista".
So, in general, it is a _bad_ idea to connect any computer running Windows 98 to the Internet -- Microsoft has issued many "security-fixes" in the 4 years after they stopped supporting Windows 98 and Windows ME.
Nov 23, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140. No Sound. Checked lighted button,
Make sure any programs that consist of sound for example " Soundman" is running this can cause a conflict with your audio. Check for updates if you can
Jul 30, 2009 | Dell Inspiron XPS M140 Notebook
Laptop has black screen, woks when hooked up to external monitor
just re-connect LCD connector properly its a loose connections. check also inverter maybe loose.
May 29, 2009 | Dell Inspiron XPS M140 Notebook
LCD screen is faint XPS M140
You backlight is failing. That is the bulb that provides the brightness to the screen. You need to replace bulb which is very tricky to do unlesss you have experience or replace the screen.
Please rate this if helpful.
Thanks
May 05, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
Can the geek squad fix my dell computer?
Stay away from geek squad.. a bunch of **** with all honesty.. You might get one good tech out of 20. Reply back with an exact model number.
Jun 15, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron XPS M140 Notebook Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
