Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Stanley Thermos We have 2 Stanley Thermos' and after washing and drying to put away, when we got them out to use, they both have black residue inside. It looks almost like rust, but it's black instead. What can I do about this? It doesn't wash out. I have called your 800 number twice with no reply, and this is not making me happy because we paid good money for these thermos' and I can't understand why I'm not getting any response to my dilemma. I feel that with the money we paid for these thermos' so we could have a lifetime warranty, but when there is an issue, I can't get any response. I would certainly appreciate an answer for a solution. Thank You. Connie DeLeo (315-923-9256) connied4@verizon.net
I just called 10 minutes ago and got a response. Call this number and then push #1. Tell the rep that you have 2 themos' and need them replaced but don't have the receipt anymore. The rep will want the #'s on the bottom of them. Said I'd have a replacement in 3 weeks. BTW, mine had same problems as yours but I didn't tell them what was wrong, just that it has a lifetime warrenty and I wanted a new one. Hope this helps you.
Posted on Sep 07, 2010
  • extreme 1999 Sep 07, 2010
    PS Here's the number, sorry. 1-800-251-4535
Why after cleaning my thermos with bleach does it no longer holds heat?
The bleach would not have affected the inside of the thermos, but it may have deteriorated the seal of the cap? Try filling it with water, cap it and turn it upside down and leave it for a few hours, see if you get a leak. Or you could submerge it in the sink and look for air bubbles.
Mar 02, 2015 | Stanley Classic Vacuum Thermos 16-Ounce...
What to do when stanley thermos no longer keeps my coffee hot . is there any way to fix it.
thermos cant be fixed once the glass gets punctured. it is cheaper to buy a new one
Nov 23, 2012 | Stanley Classic Thermos 10-01229-001 24 Oz...
Need stopper for uno-vac thermos
Sure, click here Amazon com stanley stopper and chose which one fits. (p.s. take a look on seller reviews). I hope this was helpful. cheers
Nov 22, 2012 | Thermos Stainless Steel Bottle with...
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    White residue on black clothing
    I am sure you did not wash dark clothes with white, right?
    How old is the washing machine?
    Do you feel/see any white particles in the basket of the machine, when the cover is open, and it dries out inside?-- when you wipe your hand inside (the dry machine), do you pick up white residue?
    What type of soaps are you using?-- any chance they could be causing the residue?
    How hard is your water? (Do you have a water softener in the water system?
    Please tell us more about your circumstances.
    Mack B
    Dec 28, 2010 | Washing Machines
    My 6 year old Kenmore Elite DW has started leaking and has a musty smell. The dishes are clean but food residue is left on the inside door and black gunk builds up on the bottom of the dishwasher.
    Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
    Mar 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
    Inside my machine smells musty
    Make a solution of Hot water and Soda crystals obout 2 liters
    Pour it into the machine and do a couple of very hot washes.
    It will not harm the machine and will flush away residues that make the smells
    Leave the door slightly open whe nthe machine is not in use as that will allow the inner and outer drum to dry properly
    Jun 20, 2009 | Frigidaire ATF6000ES Front Load Washer
    Coffe residue inside coffee pot
    Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
    Jan 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    Black residue inside gas dryer
    r u on lp gas or nat gas if u r lp gas u need to convert the burner from nat gas to lp gas u need to call your gas co. to do the convertion
    Dec 13, 2008 | Maytag Performa PAV2200
    Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
    609 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    880runner
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
