Question about AEG L88800 Front Load Washer
What is C2 telling me on my wahing machine AEG 88730 update
SOURCE: AEG 88730 error codes
Here you go http://www.retrevo.com/search?q=AEG+88730+error+code+C3&sub=Search
Posted on May 18, 2007
zeusfaber
  • 247 Answers
SOURCE: Problem C2 with AEG Lavamat 86741
Find the drain pump (on most front loaders, it's at the bottom of the machine at the front - often with an access hatch).
Open it up (you may want to tip the machine backwards and put a basin underneath to catch the water - and be prepared to close up again if the basin gets full before the machine is fully drained). Check that the pump impeller isn't jammed with a collection of old coins.
My next move would usually be to set the machine going in a part of the cycle where the drain pump is supposed to be running, and to give the impeller a quick flip with my fingertips (taking great care to avoid injury). If the pump doesn't run until you flick it, but then starts, this is a sure sign that you need to replace the pump motor - a quick, cheap and easy fix.
If the pump starts by itself, the the problem is more likely to be one of blocked hoses.
If the pump won't start at all, either by itself or when you flick the impeller, you need to check whether the pump is getting electricity. Do this by disconnecting the machine from the mains, connecting a voltmeter across the two terminals on the pump, then switching back on and selecting a bit of the cycle where the pump is meant to run. If you see mains voltage, then again you want to change the pump motor. If you don't, then check all the associated wiring before starting to look at the main timer. Disconnect the power before removing the voltmeter connections.
A.
Posted on Mar 05, 2008
  • 1294 Answers
SOURCE: aeg washing machine
Click on 'washing machines' (below FIXYA) on this website, & search witrh your model number. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
Posted on May 30, 2008
jason0110
  • 66 Answers
SOURCE: My machine is a AEG
it is an easy job if you can tilt your machine back and get underneath you will see a motor with 2 brushes 1 at either side undo 2 small nuts on each brush then it will drop down pull the wire off and connect new and replace all will be fine goodluck and unplug regards jason
Posted on Jun 15, 2008
  • 30 Answers
SOURCE: AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Posted on Aug 21, 2008
Have a aeg oko lavamat 88730 update runs for short time then shows C1 what is wrong with it and how do I fix it and how much
C1 is fault in prewash cycle and means no water inlet.
Could be: vaIve does not open or interruption, flow rate to low.
So, I suggest to check an following parts: water inlet, clean sieve, inlet valve, pressure sensor, wiring.
Dado
Jun 12, 2016 | AEG Washing Machines
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
C2 error
aeg lavamar error c2
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
AEG 88730 UPDATE
Aug 18, 2008 | Washing Machines
My machine is a AEG Lavamat 88730 and the carbon bryshes need changing is this an easy job I could do if so how is it done Thanks Mike
Jun 14, 2008 | AEG Washing Machines
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
AEG L88800 Front Load Washer Logo
62 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
