Hi i have a lg 50ps-3000-zb with hdcp issues
Hi i have a lg 50ps-3000-zb with software level v.3.38.0. im having hdcp issues the picture/sound drops out for a second then comes back. it is used with a denon avr2308 reciever. the denon has latest firmware in it and has been tested with another tv and is ok. what would you suggest?
zjut
  • 106 Answers
SOURCE: LG 50PX4DR plasma tv
Open the back cover and check the fuse on YSUS Board. If the fuse was gone, replace the YSUS board or ZSUS board.
Posted on Jan 14, 2008
  • 5 Answers
SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Posted on Jun 03, 2008
The Slash
  • 53 Answers
SOURCE: LG 32LC2R - No Picture Sound Ok
Hello
It sounds like there may be a issue with the inverters on the Lcd panel, yes you will need to contact a repair center.
Posted on Aug 19, 2008
  • 10 Answers
SOURCE: sound issue on LG 42LG50
make sure the dish network menu settings in setup under audio are on high. Some tv's require it to be off. Try both and see what works. Also the delay is caused by digital conversion. new stereos have settings for this delay and they have delay boxes for sale online. You could try to change your delay settings on your stereo surround to help. I had to do this.
Posted on Jan 08, 2009
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
I keep getting a HDCP error on my LG tv, I have a ROKU, and it doesn't matter if it is is plugged into the first port or the second port, arc. Or if is HDM1 or HDM2, the error message keeps coming up
hi this is caused by a stup1d copyright protocol in hdmi called HDCP.
If your TV is an older model it may not have HDCP compliance.
I call it stup1d because you can be legally watching content and still have problems if your tv is not HDCP compliant.
see
https://www.howtogeek.com/208917/htg-explains-how-hdcp-breaks-your-hdtv-and-how-to-fix-it/
Jul 06, 2018 | LG Televison & Video
Anyway of upgrading TV to support HDCP? Will not support HDMI w/o it/
look on ebay for an adapter try "HDCP to HDMI adapter" as a string i wont look but i can bet your not the only one
and some guys are good to solve simple wires and balance issues
Nov 30, 2014 | LG Televison & Video
Replace lg50ps3000-zb lcd panel
Just contact the nearest authorised service center for LG at your town. They only can provide it to you. It will be best to replace LCD panel by company technicians. There are so many adjustments to have done, after Panel replacement. You have to enter the set's service menu options to do this. It is really a very skilled work.
Jul 12, 2012 | LG Televison & Video
I just purchased the LG 32LD400 TV. at random times, the sound will drop from whatever level it is set to the sound level 10. It has done this multiple times. Is this a common issue? Is it a setting...
I have this same problem except mine drops to "11". Did you ever find out anything about this? I guess I have to have it fixed under the warranty.
Dec 28, 2010 | LG Televison & Video
Only sound no picture on my lg42pc55-zb
Hi
You will more than likely find this to be the Y-SUSTAIN board that has failed.
With the back removed from your tv it is located to the left hand side (rectangular board) and will have 2 x fuses on it, you will see 1 of the fuses is blown, this is a very common fault and can not be repaired just replacing the fuse.
Its the actual big IC under the heatsink that fails.
Get the part number of the board and google or ebay for a replacement. Replace and all should be well.
Hope this helps.
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
Bluray movie playes sound but no picture, HDCP problem?
In order to provide the proper solution to this, I need to know how this unit is connected to the TV. Also, when using the PS3 in game mode, do you get both picture and sound? What is the make and model of the TV involved here?
There are a number of reasons for the loss of picture. I will assume that you have selected the correct video input and video type. But for confirmation, please provide those details as well. Once you update this, I will try to give you an explanation and potential solutions.
Thanks,
Dan
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Hello
Aug 15, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Trouble using zoombrowser EX with windows vista ultimate
I found the problem.
This is what I did to solve the problem:
1. stop ZB
2. Delete all the ZbThumbnail.info files under "my pictures" and "my documents"
3. Move out all photos and directories from under "my pictures". Move them to a temp directory. ex d:\temp.
4. Start ZB and download some pictures from memory card
5. Then start moving files from temp dir to "my pictures", testing ZB occasionally.
Thanks
Feb 21, 2008 | Canon PowerShot S2 IS Digital Camera
DVI input does not work. Senses input but shows no signal.
Could be a hdcp issue. If the bluray player is High-bandwidth Digital Content Protection but the tv isnt then youll get no picture, can you connect via scart.
see here for info
http://en.wikipedia.org/wiki/HDCP
Feb 05, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
