Question about Dishwashers
Have power but after selecting programe required light just flashes but does not start wash?
  • 111 Answers
There is a switch in the latch on the door that won't let it accept a program, cause the sensor is telling it the door is open,if you can get at the switch, clean everything around latch and switch, make sure it's adjusted properly and all working smoothly, try again, if no work, replace switch, I've heard of this going the other way and people got all there dishs locked up in the dish washer because the safety latch failed,
Posted on Feb 01, 2010
Testimonial: "If it works after your response will be very pleased, thank you"
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Washing machine fault
Too heavy, overloaded, off balance is my take from what you describe.
Mar 08, 2012 | Washing Machines
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
End light flashes four times/sound signals too, after selecting any program, machine will not start...any ideas?
This is most often a problem with the door lock. However, can you provide the exact make and model of the machine and let me know if the door is locked when it refuses to activate the program.
Also try disconnecting or tripping the power to the machine for 30 minutes - reconnect and see if it starts the wash.
Thanks.
Feb 13, 2010 | Washing Machines
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing machine problem
Possible sticking door lock or a faulty PCB located in the back of machine, however watch the red light and count the flash pulses, if there is a compnent fault the self diagnostics should emit a fault code, the light will pulse and then pause, you need to count the pulses between the gaps.
Jan 04, 2008 | Washing Machines
Lights flash but wont start
If the dishwasher is still under warranty, best thing will be to conntact for manufacturer service !! The problem you describe could be cause off : * A Defective switch level that doesn't "shows" that there is enough water in the dishwather and therefore will prevent program's advance. * A defective heater- If water will not reach need temperature it will prevent program's advance as well. * Defective timer - Dishwasher's heart. In case your washer is over its warranty period and you would like to solve your problem by yourself, let me know and I will instruct you step by step how to to find the defective part and how to fix it. Good luck !
Jun 09, 2006 | Frigidaire 24 in. GLD2250RD Built-in...
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
Owen Barnes
