Question about Keurig B60 Coffee Maker
Keurig when drawing water in takes a long time then turns off, sounds like it is clogged in some way
    Problem Solver:
  • 5 Answers
Try using a straw. Use it to blow thru the whole at the base where the reservoir sits. I fixed mine this way.
Posted on Jan 16, 2011
    Scholar:
  • 28 Answers
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. Hope that helps! Best of luck...
Posted on Feb 07, 2010
My keurig b70 coffee maker says prime. sounds like the pump works for awhile then stops. prime lights up on the screen and doesnt let me do anything else why
Mine would brew the first cup fine, then the pump would run but would not draw water from the reservoir. I turn it off, turn it back on it would draw water for one cup then would not draw water again. I unplugged it waited 30 seconds and plugged it back in, assuming that would reset the electronics. It worked fine following the PDPU (power down, power up) procedure. Simply turning it off will NOT reset the processor, you MUST unplug the unit. Remember to wait 30 seconds or so prior to plugging the unit back in.
Nov 28, 2011 | Keurig Platinum B70 Coffee Maker
Sounds like it draws water, but won't make a cup in the morning. I usually have to power cycle a couple of times and then it works fine rest of day.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jul 08, 2011 | Keurig Platinum B70 Coffee Maker
The display always reads Not Ready. I have to turn the machine off for at least 10 sec now every time I make a new cup of coffee. It also sounds odd when it's drawing the water in to the heating...
heatman101=-=-
Jun 18, 2011 | Keurig Platinum B70 Coffee Maker
Will not draw water from the reservoir
Sounds like it is too scaled up to work now. Use and care guide recomend you do it every 3 months and if you dont it builds up to the point that it gets completely clogged and will not pull in water.
Mar 05, 2010 | Keurig Platinum B70 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
390 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
