Question about Select Brands Washing Machines
Oil marks on my clothes after washing
After washing clothes there seems to be grease or oil marks on the clothes. is it possible that a seal under the spindle needs replacing?
  • Select Brands Master
  • 3,463 Answers
It could be an indication that the main bearings are failing, or it could be an effect known as grease balling.
This is caused by washing at too low a temperature, or not using enough powder, or using the wrong type of powder.
If it is the bearings, then I would expect it to be getting noisy, particularly on the spin cycle.
Hope this helps.
Please rate my solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "great help thanks very much. this could save a lot of money and work."
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
Kenmore 70 grease spots
If your starting to see black grease or oil spots on your clothes after washing and it seems to happen more and more chances are the transmission seal is busted and either the whole transmission or just the seal needs replacing.
Apr 24, 2012 | Kenmore Washing Machines
The clothes are being pulled under the agitator, getting tangled and grease/oil marks on the clothes. What can be done to correct this?
If the clothes are being pulled under the rotating plate, you need to replace the plate because the plastic-sealing-edge strip is not pressing tightly against the inside of the washtub. I did this and all has been good for a year. The grease COULD be from the rotating parts under the plate, but there is also a post on this Fixya site that has to do with replacing a transmission seal. I have not had the dirty-streaks problem, so I cannont comment on a fix for that. BUT, replacing the rotating plate WILL fix the issue with pulling clothes under it.
Mar 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Seems to bee grease getting in from sum where as
Take off the agitator and look for signs of oil coming from under collar that supports the agitator.
If so it means that the seal has gone and water has got into the transmission forcing the lubrication oil to be pushed up through the seal.
Big job to repair.Sorry
Feb 23, 2010 | Westinghouse WWS833ES Super Capacity Top...
Fairly new ge washer spitts out grease/oil from under agitater
Remove the agitator and inspect the upper shaft bearing condition by trying to push the shaft in various directions. It should not be possible to observe movement in a good bearing. If the bearing looks good, then replace the rubber seal just under the plastic block on the shaft top. You must be very careful not to damage the shaft where the seal lip rides. If the bearing is loose, the machine must be torn down to remove the shaft from the supporting post.
Aug 15, 2009 | Washing Machines
When we run the wash, black marks appear on some clothes. No pens or foreign objects are in the washer.
It can either be the rubber seal around the washer door or the bearings (normally sealed) for the tub may be leaking and getting grease into the tub. I think usually the bearing grease is brown in color. For some reason, as the rubber seals deteriorate, they tend to mark up clothes. At least that has been my experience. You may try wiping them down with some sort of cleaner (fantastic, greased lightening, etc) and see if that helps any.
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Grease on my freshly washed cloths
This sounds like a seal problem in the base of the agitator. This seal is what keeps the water inside the machine and the grease out of the wash basin. It is not something that should be attempted to repair if you are not mechanically inclined.
To get the grease out of your clothes, use an engine de-greaser which can be bought from any automotive parts store. You just spray the de-greaser on the area where the grease is located and rub it in by hand. You will need to use lots of soap to remove the de-greaser from your clothes, and might have to wash the item twice, to get rid of the de-greaser smell from the clothes.
Note, the de-greaser will break down all oil stains and grease stains, and is an oil by-product. This has worked for me on many occasions, but I have only used it on denim jeans and cotton shirts, with excellent results.
Aug 14, 2009 | Fisher Washing Machines
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine problems
Oil or grease due to failing seal on the drum shaft.
Jan 14, 2008 | Washing Machines
Washing Machines Logo
165 people viewed this question
Top Select Brands Washing Machines Experts
Are you a Select Brands Washing Machine Expert? Answer questions, earn points and help others
