Question about Kingston Computers & Internet
Hi i have a 128GB Kingston USB memory that I have tried to format it to NTFS format, but it would not. but it works in fat32. I users windows vista sp2. have tried a program called HP USB Disk Storage Format tools V2.1.8. you have more suggestions?
    President:
  • 281 Answers
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format USB memory
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 06, 2010
Kingston DT200/128GB not able to detect
Go to your Admin Tools, computer management, disk management and if it shows up there but with a black line across the mini window it showing in, it will need to be enabled for windows to see it. if nothing like that is working, it may just be a bad drive. kingston 128Gb flash drives may not be formatted correctly for windows to see that its plugged in
Oct 18, 2013 | Kingston DT200/128GB 128GB DataTraveler...
I have a kingston 2 g flash drive. I put a large number of files from my Dell computer with Vista and the flash works fine on ANOTHER of my computers, a Toshiba Laptop. I put some files on my kingston...
this could be due to the format. i would try different formats on your usb. vista normally reads both but your format may be fat32 which is hit n miss. you can try UDF or FAT. I would format on a vista machine. insert, right click on the drive and select format. you may have to do both with a single file to test reads on both boxes. good luck.
Jun 13, 2011 | Kingston 2GB Secure Digital Memory Card
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston usb asks again and again format
Insert the drive, go to "My Computer", locate the drive in the list, right click it, select "Format" and follow the instructions. Most flash drives are FAT32 but you can format them NTFS
Sep 21, 2010 | Kingston flash memory card - 256 MB -...
How do i format my sandisk 8gb m2 memory card to work with my sony ericsson w395as it doesnt seem 2 work when its in the fone ive tried formating it on my pc but must be different settings for the fone
hi are you formatting it as NTFS? windows xp, vista and 7 format using the NTFS format, try formatting it in fat, or fat32 this could be the reason it is not working....hope this helps
Mar 18, 2010 | SanDisk 4GB Memory Stick Micro M2 Memory...
Uploading to kingston data traveller 64GB corrupts my files
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
Dec 27, 2009 | Kingston Technologies 512MB DataTraveler I...
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant...
Hi
try to format your kingston with
Following tool.(HP USB Disk Storage Format Tool )
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
Oct 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Windows says not enough space on pny 8 gig flash drive
Try formatting the drive as NTFS instead of FAT32 (assuming you are using it only on Windows computers). FAT32 doesn't support files over 4GB.
For more info, see http://www.google.com/search?q=fat32+file+size+limit
Feb 08, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
1,583 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
