Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
My refridgerater went out Saturday and now my freezer went out last night. what do you think it would be?
  • 619 Answers
The overload relays at the side of the compressor have gone bad. Not an expensive repair and not hard to do. Replace the overloads and you're back in business.
Posted on Feb 01, 2010
I own a CANON EOS REBEL T1i EOS 500D. I used it in perfect order last saturday, went to use it yesterday afternoon and i have nothing viewing on the LCD. The camera still takes photos fine. Just nothing...
hi there, have you pressed the DISP button (see red line above) or REVIEW button (blue line) yet??
if there`s still nothing appear on the LCD, i assume the LCD connector from the body is broken
you can claim it to be repaired to the store you bought it from, since the warranty still valid
hope this post will help
Jan 05, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Whirlpool refridgerater-freezer model#
check relay in compressor. check if compressor is running
Feb 08, 2010 | Refrigerators
Freezer works, refrigerator doesn't, fan is working, no cold air flow from freezer to refridgerater
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
I hope that this helps you to solve your problem.
Thank you for using Fixya!!
Heatman101
Nov 25, 2009 | Whirlpool Refrigerators
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
I have problem with my temperature inside,freser is good,
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Dec 10, 2008 | Refrigerators
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Refridgerater
It could be the defrost thermostat located on the condenser coil on the left side of the fan in the freezer compartment... or else it could be the defrost timer located in the refrigerator behind the dome cover... defrost the freezer and make sure the drain tube is not blocked nor the air passage which blow cold air from freezer to refrigerator compartment below. Water should drip from freezer down hole into tube to an evaporator pan on the top of the compressor near the floor in the back. Make sure the tube is free flowing by pouring some hot water down it before restarting refrigerator. Rarely the defrost heating element shorts, but a simple continuity test will determine if that is o.k. Make sure the refrigerator is uplugged before checking any of these areas... there's 120 volts all about and with water and ice it can cause quite a jolt!
Oct 05, 2008 | Roper RT14DKX Top Freezer Refrigerator
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
127 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
