Question about Sewing Machines
Thread is jamming in the bobbin area and material will not advance. I recieved one suggestion and it was unsuccessful. Thank you Gil Sr
  • 3,741 Answers
Thread jamming is usually not indicative of a problem with the bobbin itself. Just be sure the machine has wound the bobbin evenly and not all clumped in the center of the bobbin but evenly from side to side. material will not advance this happens if the problem is with the blocked feed dogs are the feed dogs are getting cracked /worn out.
Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race.
Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 09, 2010
Deco Bernina bobbin jammed, now bobbin won't work
remove bobbin and reinsert. Re thread needle . Make sure the right size of needle for the material. And check that there is not a wad of fluff under the feed dogs.
Best wishes
Aug 22, 2014 | Bernina Sewing Machines
Needle Jams In Bobbin Case Area pfaff 1540
First, make sure there is no debris and scraps of thread in the bobbin area. I'm sure you did that already. I assume you also tried it with another thread just to be sure. I would suspect that the timing went out of whack. The machines depend on a synchronization between the needle motion and the bobbin action underneath. I once had a Singer that slipped and I had to reset the timing. If it is the timing synch problem then it would happen consistently and not work sometimes and then not work other times. G
Jan 27, 2014 | PfaFF Sewing Machines
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
Brother 700e
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
When I embroider, the back of the material gets enormous knots in the thread. What can I do to fix it?? Thank you!!
change the needle
check to make sure the thread has not come off the thread take up lever
change the thread on top & bobbin area
clean under the needle plate & bobbin area for loose threads or lint
check to make sure the bobbin is not warped
check to make sure there are no burrs on needle plate
make sure the bobbin is wound correctly & inserted correctly
Aug 11, 2011 | Brother Sewing Machines
Model 2200 EC1 SERIES The top thread Bunches and tangles on the underside of the sewn material. I have checked that the upper thread tensioner is in good order. When I observe the thread in the shuttle...
try these suggestions
1.check to see if your needle is bent-place needle on flat surface & see if it rolls good
2.if needle make poping sound when going thru fabric it is blunt
3.check to make sure the bobbin is not warped
4.make sure there no loose thread or lint in bobbin area
5.make sure there are no burrs on bobbin or bobbin case
6.check to make the thread does not come off the thread take-up lever
Aug 23, 2010 | Toyota Sewing Machines
My top thread keeps wrapping around bobbin case and jamming does anyone know how to fix this tyvm
1.check needle to see if it bent-roll needle on flat surface & see if it roll true
2.check to see if thread is coming off thread take-up lever
3.check the thread tenison
4.check for lint in the bobbin case area
5.check for loose thread in the bobbin case area
6.check to see if the bobbin is bent or warped
Jul 28, 2010 | Singer 7442 Mechanical Sewing Machine
Singer Simple 3116
Your problem is a simple one.Jamming is due to thread getting trapped on the bobbin holder.All you need to do is to unscrew two screws holding the the bobbin holder clean the same and reasseble it.your problem will be solved.N.Govindarajan
Jun 09, 2008 | Singer 3116 Simple
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
