Question about XFX GeForce 6200 Graphic Card
My screen only shows color stripes when i turn it on. Is it a graphic card problem?
  • 813 Answers
It can be a graphics card problem as this issue comes when there is no signal to the Monitor from the Graphics Card. Other issues might be damaged cable connecting the monitor to the CPU or when the graphics card is not properly inserted in the motherboard.
Posted on Feb 01, 2010
I had the same problem 6 monts ago . I fixed it by removing the monitor cable from the gpu(9600 gt) to onboard graphics and back and some other similar stuff, rebooting the system several time during the process(until success)........
Now it has come back!!! This time it just ain't going!!! Still trying diff stuff though......
Posted on May 05, 2010
  • shaishavgame May 05, 2010
    Hey just came to tell that the above fix(read my upper post) fixed my problem....i was dripping in sweat and my mom said take a rest, i thought yeah i should give the system some rest...i came on the net top find a solution , after writing my above post i tried again and the problem was completely fixed...it should cause my gpu is only 1 year old....wonder if this might help u in any way....but don't loose hope it might just go away with slight effort, just like it went away twice with me.....
Sony VAIO PCG-392L screenwith striped colors
Hook a spare monitor to the video output of the laptop, if picture okay! the LCD panel display is defective and most be replaced. But if symptom is the same on both screens it indicates a bad Video Graphic Card normally built into the motherboard.
Mar 19, 2012 | Sony VAIO PCG-505TR Laptop
My inspiron 8100 has 64MB of graphics card memory but it is only showing 32MB before the lcd went bad and shows dark screen with rectangular lines of different colors. I purchased lcd on ebay and still...
The graphics card - it overheated because the radiator makes a bad contact on the chip in these models. Unfortunately the damage is extensive, the repair would cost even more than another working laptop - just get a new one.
Jun 07, 2011 | Dell ATI 64MB Video Card - 9J057 Graphic...
My startup screen not showing correctly.that time screen showing some fals colour
Hi, if you mean there is coulour stripes or splashes on screen then this is a Graphic Card problem. Probably you wil need a new one.
May 22, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
My ACER Monitor shows green striped pixels wherever there is BLACK colors on the screen. Eg: Shadows in a video game, wallpaper with black background. It happens on and off, but the more it happens the...
The problem is either the video graphics card in the computer or the monitor, if you have a backup monitor check the computer first, if the same problem persists the video graphics card is bad. If however the second monitor is fine, then your monitor is the problem, The screen is breaking down, if you have a detachable video cable, sub it for another to make sure there are no issues,if okay your monitor is the problem and not cost effective for repair.
Jan 03, 2011 | Acer V193 Monitor
My 21" mid 2007 imac periodically freezes, the
Try booting it into single-user mode holding down Command(Apple) and S buttons when powering up. Then in terminal console, use chkdsk -fy. Use it and use it again until comes back with something like "Volume appears to be OK". Then use command: mount -uw / and then type reboot and try booting normally.
If it does not fix your problem, it's most likely a hardware issue (logic board / graphics card), and you should take it to an Apple Authorized Service Provider.
-juuko
Nov 08, 2010 | Apple 24" iMac Desktop
My xfx 8800 gt displays stripes on monitor. It starts when the computer starts up at the post image. In windows it gets worse. There are tons of stripes on the screen. The problem started with games...
This is a damaged onboard graphics module. Unfortunately it needs replacement. if you have a graphics card inserted then you can simply install another one. If you buy a different type. ensure you install all the drivers from the install disk before you turn off machine and swop out the cards.
AndystUK
Aug 30, 2009 | Computers & Internet
Motherboard or on-board graphics card failure
I had the same kind of stripes on my hp dv9000. I read in forum that it was a heat problem, that loosens the soldering on the GPU chip.. I wrapped it into a towel for approx 30-60 min.. That removed the stripes in bios screen..
Jul 10, 2009 | Acer Computers & Internet
Stripy Boot Up
is it a new graphic card? Sometimes that happens when the graphic card gets overheated and fries up some chips. and sometimes those lines appear when the graphic card has fault in Direct Draw. Try setting your BIOS settings to default. if it doesn't work, i recommend you to take the graphic card to the nearest hardware tech ;)
Oct 16, 2007 | SPARKLE Computer GeForce 6600GT, (128 MB)...
Xfx 6200LE
Hi Pat, Sounds like a faulty video card to me. If the machine or video card is still under warranty talk to the manufacturer as they should replace any faulty hardware. If it's not under warranty I would suggest you swap the video card with another one if you have one or replace it entirely. Good luck, Bernard
May 14, 2007 | XFX GeForce 6200 Graphic Card
XFX GeForce 6200 Graphic Card Logo
458 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
