Question about Serif DrawPlus 7 (1094854SF)
Error message when using serif drawplus x2
After adding a border to the animation using the wizard the following 2 error messages appear
drawplus.exe application error
the exception unknown software exception (0xe06d7363)occured in the application at location 0x7c812afb
microsoft visual c++ runtime library
runtime error!
program c:\progra~1\serif\drawplus\x2\program\drawplus.exe
abnormal program termination
any ideas as to why this is happening
2 Suggested Answers
SOURCE: Hi, I have Serif PhotoPlus X2, PagePlus X2,
how to use it
Posted on Oct 26, 2010
I tried installing my new Serif x4 software and it did not complete the installation due to the following error message: installation error: 'wp.cab' / 2350 code
It's missing a major cabinet file.
Are you using a genuine disk or download?
If a download, redownload it, the file is corrupted.
If on disk, use original disk NOT a copy as it won't work.
Dec 30, 2010 | Serif WebPlus X4 for PC
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
When installing OT5 the resolution goes out an I get error message saying it cannot locate the CD. I meet the system requirements. Not sure what to do to fix it.
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jan 04, 2010 | The Learning Company Oregon Trail 5th...
Last night I turned my printer off by pressing the on button. The sreen said, " Shutting Down". I pressed the on button this morning expecting it to start but it didn"t. How do I start my printer? Thanks...
Try this:
1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off...
This message is caused by the hpcmpmgr.exe , program installed on most computers to support HP products, such as the HP Photosmart, Deskjet, and All-In-One printers. The error message is generated when the program becomes corrupt or conflicts with other system components. In order to resolve this issue, follow the steps below to install an updated version of hpcmpmgr.exe that will resolve this error (click the link).
Downloading and Installing the Update
  1. Click the "Download now" to begin downloading the update.
  2. When the File Download window appears, click Open to start installing the update.
  3. The Install Shield Wizard will appear and display information about the update. When the update has been successfully installed, a
    Thank you. You have successfully downloaded and installed the fix. Please restart your computer
    message will appear. Close all programs and click OK to restart the computer.
NOTE: In the event of an unsuccessful installation of the hpcmpmgr.exe update, the following message will appear:
Recommended update to resolve hpcmpmgr.exe and hpdarc.exe errors. There was an error while running the fix. Please try again.
If the product software is uninstalled and reinstalled at a future date, the patch will need to be installed again. HP Software Update will automatically offer the update for future downloading.
Let me know for the results. Hope helped with this.
Nov 19, 2009 | HP Office Equipment & Supplies
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
Te.co.ukFile opening error
Did you try uninstalling and re-installing the drivers. Uninstall everything including the canoscan tool bar, Arcsoft photo studio and Omnipage. And re-install.
Hope that helps,
Sai.
Jan 13, 2009 | Epson Perfection 1240U Flatbed Scanner
Perpixel rendering related problem
The IGP in VIA/S3G UniChrome Pro IGP stands for Integrated Graphics Processor. The WindowBlinds error message indicates that onboard graphics tend not to support per pixel acceleration. There's your answer: your graphics cards do not support this kind of advanced processing; unfortunately a driver update isn't going to solve the problem, as it's hardware-related. You will need to upgrade to a more powerful card if you want to use the translucent borders.
Regards,
Javabytes
Nov 11, 2007 | Computers & Internet
Computers & Internet Logo
339 people viewed this question
Top Serif Computers & Internet Experts
Martin Murray
Jax Planet
Jax Planet
 Grubhead
Grubhead
Are you a Serif Computer and Internet Expert? Answer questions, earn points and help others
