Question about Panasonic PT-53WX42 53" Rear Projection Television
Resistor Hi I have a Panasonic big screen tv i need a RESISTOR ( R7059 (it was 2.2 Ohm 2W ) Can you help me fine one to buy . The modle # is PT-53WX42F. Thanks
  • Panasonic Master
  • 8,617 Answers
Electronix.com or matelectronic.com should have that resistor. Be sure to specify flame resistant 5% tolerance that is a convergence resistor so it needs to be flameproof and install it up off the board like the origional was.
Posted on Feb 18, 2008
Need info
A 2.2 ohm resistor would be coded red-red-gold-gold.
Feb 25, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Need help
I believe red, red, gold.
Feb 25, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TV projector PT 4743G
yes the convergence ics will blow that resistor
Jan 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Sony 57ws500
Ok, here are details of all resistors ...
R7324= 1k 1/2w
R7326= 220 ohms 1/2w
R7301= 10 ohms 1/4w
Need further help, let me know please.
Nov 06, 2008 | Sony KP-57WS500 57" Rear Projection...
Toshiba TP43H95
Needed two convergence circuits., three Hi-Temp. capacitor-filters and one 1.8 OHM-2W Power Resistor. ($550.00 parts and labor)
Aug 27, 2008 | Toshiba TP43H95 43" Rear Projection...
I had projection tv.modle#pt-47wx49.i had convergence problum.i change both big ics.one resistor is blown out. what is the valueof resistor place on R7050,or R7001,or R7059.please help me.
R7050 and R7059 are both 2.2ohm 2watt Resistor R7001 is either 82 or 8.2 ohm if you give me the colors of the bands on that resistor I will let you know for positive what the value of R7001 is
Apr 26, 2008 | Televison & Video
53FDX20B
I would start 1st by checking all resistors ie.
RK43 2.2 ohm - 2W
RK47 1.5 ohm - 2W
RK51 2.2 ohm - 2W
RK55 1.5 ohm - 2W
RK59 2.2 ohm - 2W
RK63 1.5 ohm - 2W
If I were you I would also replace the convergence chips. From the above thread it's clear that they are of different quality so they may last different lengths of time (B&D is a good place to buy good quality ones).
I found a free pdf service manual for 53FDX20B on a Polish web site: http://instrukcje.elektroda.net/main1750.html
other models try here: http://www.webtronix.ca/hitachi/index.htm
http://www.asm-service-manual.com/List/Hitachi%20List%20ASM.htm
Download pictures from my repair (Password: delirious).
http://www.uploading.com/files/HGGLJLXC/Delirious.zip.html
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 06, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Blurred picture
Hitachi > 53FDX20B blurry picture
RK43 2.2 ohm - 2W
RK47 1.5 ohm - 2W
RK51 2.2 ohm - 2W
RK55 1.5 ohm - 2W
RK59 2.2 ohm - 2W
RK63 1.5 ohm - 2W
Jan 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Sony 7 blinks
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Dec 11, 2007 | Sony KP-65WS500 65" Rear Projection...
Panasonic PT-47WX51CE convergence
the value of r7050 is 2.2 ohm 2W
i might be able to email the manual but its big - just let me know and i will send it or look up anothe part # for you
thanks
scott
Sep 29, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
