Question about Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range
Broken oven element
Bottom element brokenin 90 cm single electric oven Second time in five years. Where best to get replacement? Can't get an answer from my contact at Lofra in Italy
  • Anonymous Mar 22, 2014
    When oven is heating up chemical or electrical smell is coming from the lofra oven or possibly from the back of the oven
All sorted now. Found a company in Liverpool, very helpful. Posted replacement today.
Posted on Feb 02, 2010
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Oven does not heat up
Hello and sorry to hear about your problem.
It sounds like your oven heat element is burned out or your oven control knob is defective. these are the only 2 issues that can happen 90% of the time, or a broken or worn wire someplace.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
Dec 21, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Bake element not working-electric oven
i had the same problem with my oven i think its a contact that conects to the bottom element the top one will work and olny go on broil cuz thats the olny time it comes on
Dec 24, 2009 | Whirlpool RBS305PR Electric Single Oven
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Oven turns on by itself
only thing i could say here is replace the control or clock its real name is an eoc electronic oven control now the part is under a five year warrenty but you have to pay labor and use some one that is authorized for ge warrenty work check your owners manuel for second to five year warrenty and go to ge web site to locate servicer in your area http://www.geappliances.com/service_and_support/service/
Jun 04, 2008 | GE JKP20 Electric Single Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range Logo
435 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
ray gallant
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
